Front end transplant, Firestorm onto VFR750
PostPosted: 20:46 - 01 Jun 2010    Post subject: Front end transplant, Firestorm onto VFR750 Reply with quote
Couple of reasons for this. Not least of which is that the forks on the VFR were pitted and fixed with araldite a couple of years ago. I usually reckon on this lasting 2 years and not to disappoint me, when I went out to do this job, it had shat all the oil from the right fork all over the yard.
I also find the VFR underbraked, especially when loaded. The Firestorm has 4 pot opposed callipers rather than the two pot, sliding ones on the VFR.
A lot of people say the firestorm forks are a bit wooden but compared to the tired, boingy, leaky efforts I have on now, it can only be an improvement. They also have adjustable damping.
You need the following parts off the firestorm:
1) Forks.
2) Wheel spindle and spacers (the firestorm one is longer)
3) Brake callipers.
4) Master cylinder (lever is the same so get one with a bent lever cheap off ebay Wink )
5) Mudguard.
All the other bits fit so you retain the handlebars, yokes and front wheel.
Fitting was totally uneventful. Unbolt the VFR parts, bolt on the firestorm parts and bleed the brakes.
One thing is that the firestorm forks are 10mm shorter. This will alter the geometry a fair bit. I'll need a longer road test to see if I can live with this (might even be an improvement?). If it's too twitchy, I can always go back up to a standard, 70 section front tyre which would go some way to raising the front end again. I've been running it on 60 section ones to speed up the handling.
The shorter reach means the standard brake lines are a bit more curved about. Not too much though.
Extra twiddly bits and a really tacky looking remote reservoir
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0692.png
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0688.png
Spindle is wider to accommodate clamps on both sides
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0691.png
More brakes can only be a good thing. Note fork oil all over tyre.
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0689.png
I don't think the yellow goes very well with the rest of it though
https://i48.photobucket.com/albums/f216/stinkwheel/DSCN0687.png
So, I was looking at £180 to get new fork stanchions and my brake callipers needed a total rebuild.
I've spent:
Forks with spindle and mudguard: £70
Callipers: £65
Master cylinder: £25
Brake pads: £21
I make that a win.
chillyman0
PostPosted: 21:50 - 01 Jun 2010    Post subject: Reply with quote
nice! you did make it sound easy, so easy its really tempting me and i've only had mine less than a month. I dont know yet where you are coming from with the poor brakes as i got mine with shitty old tyres that spin out and lock up really easily. Next week on with some roadsmarts, they had good reviews
nice post, well done! Karma
1996 gsf600n (sold)
PostPosted: 22:02 - 01 Jun 2010    Post subject: Reply with quote
They're fine normally. It's when it's running heavy, 2-up with luggage that it takes a bit of effort to pull up in a hurry.
Pie-Roe
PostPosted: 22:27 - 01 Jun 2010    Post subject: Reply with quote
I agree with this. My old flatmate has the same year as yours and often complained of brake fade when making progress.
I found the same thing on my rf9 with my girlfriend on the back, or worse with any of my mates. It makes you think, when you work out you have a total weight of around 400kg on 6inch squares of tyre, on 4 pot budget brakes.
Pyro
PostPosted: 23:37 - 01 Jun 2010    Post subject: Reply with quote
pyroforlife wrote:
...a total weight of around 400kg...
How fat's your girlfriend?
Pie-Roe
PostPosted: 23:53 - 01 Jun 2010    Post subject: Reply with quote
I knew someone would say that, didn't realise it'd be scrawny little man who sits at home wanking over a tzr250 Wink
230kg bike
80kg me
55kg her
So thats 365kg, when going out on a full days riding(200+miles), I'll have a camera, food+ couple litres of water, 3/8 drive socket + spanner set, which is getting on for 400kg.
Pyro
WildGoose
White Van Man
PostPosted: 14:58 - 03 Jun 2010    Post subject: Reply with quote
Nice work.
Were all the used bits ebay jobs or elsewhere?
PostPosted: 16:39 - 03 Jun 2010    Post subject: Reply with quote
WildGoose wrote:
Nice work.
Callipers and master cylinder off ebay. The rest off a mate (he'd bought the whole front end and had already had the callipers and yoke off it).
The last post was made 16 years, 147 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 61.64 Kb
