Best place to buy bearings online?
Digitalize
PostPosted: 14:10 - 02 Jun 2010    Post subject: Best place to buy bearings online? Reply with quote
I've got a list of numbers for the bearings i need off my Hornet, wheres the best place to buy them? 2 places i looked returned no results for any of the numbers :/
1998 CB600F Hornet
Digitalize
PostPosted: 14:13 - 02 Jun 2010    Post subject: Reply with quote
Yup, numbers and closest i could describe them.
1998 CB600F Hornet
Tristan.
PostPosted: 14:23 - 02 Jun 2010    Post subject: Reply with quote
I use simplybearings.com
Digitalize
PostPosted: 14:30 - 02 Jun 2010    Post subject: Reply with quote
Swing Arm:
Shock Bottom mount bearing – 7E-HMK1720
Swing arm pivot needle roller x2 – HMK2220
Swing arm roller bearingx2 – 6002
Headstock:
Lower bearing – SAC2647-1
Upper bearing – SAC30551
Wheels:
Front wheel bearing x2 – 604DU
Rear wheel bearing x2 – 6303LU
1998 CB600F Hornet
Davie_G71
PostPosted: 16:08 - 02 Jun 2010    Post subject: Reply with quote
www.wemoto.com will give you a section for your bike and will list all of them i think.
Suzuki GSXR600 SRAD, 1997 & Kawasaki Z1000, 2003.
Digitalize
PostPosted: 16:20 - 02 Jun 2010    Post subject: Reply with quote
Im having trouble finding the Swingarm/Shock bearings :/
1998 CB600F Hornet
Davie_G71
PostPosted: 16:24 - 02 Jun 2010    Post subject: Reply with quote
I googled the part number and this came up, could the be the same as the VFR?
https://www.bikersoracle.com/vfr/forum/showthread.php?t=13467
Digitalize
PostPosted: 16:26 - 02 Jun 2010    Post subject: Reply with quote
I've found that and didn't seem to be a massive help :/ Might just have to re-use them or buy Honda ones
1998 CB600F Hornet
Phoenix
Twisted Firestarter
PostPosted: 17:37 - 02 Jun 2010    Post subject: Reply with quote
Look up bearing suppliers in your local area, trade ones usually sell to the public aswell, places like Wyko or Hayley Bearings. A 6002 double sealed is about £2 from a supplier, usually Koyo or similar the same as you get when you buy a £15 Honda one. If you take the ones you can't find with you they may be able to match if they have in stock.
The last post was made 16 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 66.82 Kb
