Suzuki GS500 K5 2005 UK clutch problem
dx90
PostPosted: 12:55 - 02 Jun 2010    Post subject: Suzuki GS500 K5 2005 UK clutch problem Reply with quote
I have a Suzuki GS500 K5 2005. When I got the bike it was a none runner. I have sorted out the electrics and got the bike running.
The problem I have now is, after I start the bike as soon as I put it into any gear I cannot get it out of gear unless I turn the engine off. It will then come out of gear.
If I put the bike on the centre stand and start the engine I can then go in and out of any gear. The back wheel turns even with the clutch pulled all the way in. I don't know if this is normal?
As soon as I try the same with the back wheel on the ground the gear clunks into gear but it won't come out of gear untill I turn the engine off again.
The bike has not been started for 4 months.
Anyone got any ideas what the problem could be?
Thanks
dx90
PostPosted: 07:47 - 03 Jun 2010    Post subject: Reply with quote
I have re-adjusted the clutch cable.
What happens now is that when I pull the clutch lever in and put the bike into first I get a clunk and I can pull away and stop and pull away again no problem.
I just can't take the bike out if 1st gear unless I stop the engine and then I can put the bike back into neutral. Does this still sound like a sticking clutch problem? If yes I will take the clutch apart and have a good look. If I really need to.
I checked the first three clutch plates, thats all I can see through the oil dip stick hole and the plates are releasing fine so far as I can tell.
With the clutch lever pulled in to take the pressure off and with a screw driver I can gently prise the clutch plates apart with ease.
Would you say that the clutch is releasing properly?
What could be the problem?
I will give the bike an oil change today to see if that helps.
Thanks
Andy
PostPosted: 08:47 - 03 Jun 2010    Post subject: Reply with quote
i would be inclined to take the clutch out anyway, check for damage with it off.
PostPosted: 09:34 - 03 Jun 2010    Post subject: Reply with quote
Where is the bitting point on the clutch lever? I think it is still badly adjusted.
PostPosted: 10:06 - 03 Jun 2010    Post subject: Reply with quote
i agree with chris-red.
adjust it on the actual engine..rather than the clutch lever, try and get it so there is no clutch drag at all.
You should have a small amount of play at the lever.
molex
PostPosted: 06:56 - 04 Jun 2010    Post subject: Reply with quote
Clutch adjusted on GS500 not "clutch lever" only!
The last post was made 16 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 47.81 Kb
