Compress Circlips
snowdude2004
PostPosted: 12:57 - 03 Jun 2010    Post subject: Compress Circlips Reply with quote
Finally today I got my new cylinder and piston in the post to replace my destroyed top end, don't ask....
Started installing the piston and have now kind of come to a dead end, I can't compress the fricking the circlips to get them in which are in the shape of a G rather than the stock ones which had two straight bit which were a piece of cake.
On the stock cylinder there was a kind of cut away bit so you could get some needle nose pliers in but there isn't any on these ones. Tried putting a clip in with the piston no attached to the crankshaft and still can't seem to do it.
Anyone got any tips to getting the sneaky buggers in?
CBT passed: 26/09/09, Theory Passed: 18/08/10, Mod 1 passed: 20/10/10, Mod 2 passed: 26/10/10.
Current Bike: Honda CBR 400 Nc23
cb1rocket
PostPosted: 12:59 - 03 Jun 2010    Post subject: Reply with quote
got a pic?
You need proper pliers to do circlip properly
snowdude2004
PostPosted: 13:00 - 03 Jun 2010    Post subject: Reply with quote
I'll go take a couple soon as I find this camera of mine.
PostPosted: 13:05 - 03 Jun 2010    Post subject: Reply with quote
The ones on my RD were shaped like a 'C' and so were nearly impossible to compress. I just used my thumb and a lot of swearing as I recall.
The 'G' ones should be a little easier with some needle nosed pliers and a lot of swearing. As Stinkwheel told me they are commonly known as "pingfukits" because that is what happens.
snowdude2004
PostPosted: 13:06 - 03 Jun 2010    Post subject: Reply with quote
Heres a picture of the new piston next to old piston and the clip.
Note the pistons are exactly the same size there's just a hidden feature on my camera that makes things on the right look bigger I swear Wink
https://i31.photobucket.com/albums/c376/snowdude2004/CIMG1214.jpg
swampy
PostPosted: 13:12 - 03 Jun 2010    Post subject: Reply with quote
WhenI used to work on Stihl 2 stroke motors I used to find that rather than try and compress the circlip and then put it in, it was easier to poke the open end of the G shape into the groove leaving the clip at a bit of an angle towards the outside of the piston. Then cover the top of the hole with your thumb, and use a small flat blade screwdriver to pull the little tang of the G inwards.... Thumbs Up
cb1rocket
PostPosted: 13:13 - 03 Jun 2010    Post subject: Reply with quote
yeah a fine needle nose pliers and lots of swearing!
Sorry dude!
snowdude2004
PostPosted: 13:19 - 03 Jun 2010    Post subject: Reply with quote
*curses loudly* I'll give it a few more attempts
Thanks swampy I'll attempt that method too
doggone
PostPosted: 13:23 - 03 Jun 2010    Post subject: Reply with quote
You can just visualise the *ping* when it flies out the door into some long grass.
snowdude2004
PostPosted: 13:26 - 03 Jun 2010    Post subject: Reply with quote
....I'm doing it outside my garage surrounded by my old ped and two cars, got myself an expensive barrier Wink
The Artist
PostPosted: 13:30 - 03 Jun 2010    Post subject: Reply with quote
Those are easy. Just put the non bent end in the groove first and use a flathead screwdriver on the bent bit to push it in.
Took me about 2 seconds for each one.
The last post was made 16 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.67 - MySQL Queries: 15 - Page Size: 66.91 Kb
