| danny125kid |
 danny125kid L Plate Warrior
| stirlinggaz |
| palmer |
 palmer Fiddled Kiddy
 Posted: 20:45 - 03 Jun 2010 Post subject: |
with mine, when i start the bike the powervalve solenoid is fully on.
try it, watch the solenoid and start the bike, it should pop straight open, if not or it sticks a bit it needs a good clean.
hope this helps  |
| danny125kid |
 Posted: 21:32 - 03 Jun 2010 Post subject: |
The power valve should be open until about 2500rpm, then closed from there until about 8000rpm (varies depending on the power valve control unit) where it opens for top end power. It is open at low rpm so that around town it regularly opens and closes to try and stop it sticking.
Good chance that the valve blade is just sticking in the barrel. Can be a pain to get them out, and gets worse the longer they are stuck for.
Easiest way to get at the valve, lift the tank, remove the battery and then remove the battery box (only a couple of bolts). You can then easily get at the valve from above. It is only held in place with 2 bolts.
Make sure when you put it back together that the valve is in the right way up.
The last post was made 16 years, 138 days ago. Instead of replying here, would creating a new thread be more useful? |
