rebuilding forks
dooley
PostPosted: 06:32 - 03 Jun 2010    Post subject: rebuilding forks Reply with quote
the right one's a bit weepy, probably as a result of the left one being whacked a couple of years back (they only replaced the left one)
easyish DIY job? get them both done professionally? what say you?
oh yeah - it's a 06 hornet showa usd jobby with no adjustment
salty21
PostPosted: 11:13 - 03 Jun 2010    Post subject: Reply with quote
get yourself a haynes if you havn't already and go for it yourself i say.
just be methodical about it and clear youself a nice space to work in, aslong as you follow the book theres not a lot to go wrong.
DrDonnyBrago
PostPosted: 11:52 - 03 Jun 2010    Post subject: Reply with quote
Hardest part on most forks is getting the damper bolt out as it just spins the damper when you go to loosen it. Best to try and loosen it before you remove the springs and oil, if you can get that out then the rest is that pretty simple Thumbs Up .
robocog
PostPosted: 21:18 - 03 Jun 2010    Post subject: Reply with quote
you say that
Just doing my first ever fork seal replacement and am taking them to work to see if the bike shop round the corner can assist
Managed to get the bolt out of the bottom, oil drained
Managed to get the top cap out that holds the springs in (not a screw in job, but a push down and pop a circlip out of the groove...so easily said , took me best part of 1/2 hour per leg to get that far
The next stage I thought was going to be easy enough is the bit that has me completely flunked
I just cannot separate the two which is completely infuriating
Been using the stanchion as a slide hammer as described in the haynes for what feels like hours and it hasn't even moved a mm
Was actually getting worried about the amount of force I was putting into it and getting absolutely nowhere
Given up and re assembled the legs for someone else to deal with
Before I put the circlips back in I remembered to put a slight kink in the ends of the ones that hold the top cap and springs in ...to make any future work a billion times easier that chasing the ends round with toothpicks trying to pry it out! ...a suggestion found on EX500.com's wiki page)
Why they didn't use a traditional circlip with the eyes so that circlip pliers could be simply and quickly used is beyond me
In a sulk cos the mozzies have feasted on me whilst I got beaten by a supposedly simple task
Regards
Rob
Needs a bigger garage...
Digitalize
PostPosted: 21:37 - 03 Jun 2010    Post subject: Reply with quote
I stripped both my Hornet forks in less than an hour, could probably have them both done in 3 hours, including cleaning.
1998 CB600F Hornet
robocog
PostPosted: 22:15 - 04 Jun 2010    Post subject: Reply with quote
Well the guy I gave them to also couldn't get them out either so I feel a bit better that it wasn't just me being a wuss
He did however manage to get the top seals out, so they got re built with fresh oil (after a flush out) when I got home from work
Forks feel OK so far (no play detected) bike will be going in for an MOT soon as my restrictors arrive and get fitted..will see what they say
I assume that if the bushes were galled up or whatever it is that causes them to make dissembly 'impossible' it would bugger the stanchions? or is it just the outer surface that gets chewed in attempting to get the stanchion out?
I guess I will find out pretty quickly and they will leak like a sieve in no time
Regards
Rob
The last post was made 16 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 58.61 Kb
