Tyre Pressures, clever clogs required.
Suntan Sid
PostPosted: 21:07 - 03 Jun 2010    Post subject: Tyre Pressures, clever clogs required. Reply with quote
I need some advice regarding tyre pressures.
Last weekend I was out with a couple of mates, it was very hot, 34 degrees to be precise, ( I live in Cyprus by the way), our ride out took us round some very nice twisties. However we all noticed that our tyres were slipping across the white line road markings.
Obviously it wasn't wet, (we're not going to see any rain here till November), I can only assume that with the road temperature being pretty high our tyre pressures were going up as we were riding.
So my question is this, given that road temperatures are always high here, should we be reducing our initial tyre pressures and if so by how much?
I should say I'm on a CBR600f, the other bikes were a Benelli 900, (don't know the model), and a bandit 600, all on standard size tyres.
PostPosted: 21:08 - 03 Jun 2010    Post subject: Re: Tyre Pressures, clever clogs required. Reply with quote
I'm not sure specifically, but for racing you generally do try and work to hot pressures - so for supercorsas will do 35 front and rear when hot.
This generally equates to around 31 front 29 rear when cold.
Suntan Sid
PostPosted: 21:18 - 03 Jun 2010    Post subject: Re: Tyre Pressures, clever clogs required. Reply with quote
The standard pressures on the CBR are 36F 42R, what do you think I should start with, given the conditions?
Ben.
PostPosted: 21:22 - 03 Jun 2010    Post subject: Re: Tyre Pressures, clever clogs required. Reply with quote
i run 30 hot on supercorsa's Shocked
follow my racing season
Race bike - R6
Road bike - sv650
PostPosted: 21:30 - 03 Jun 2010    Post subject: Re: Tyre Pressures, clever clogs required. Reply with quote
<shrugs> - the first time I got a 4th place in club racing (best result I managed) I realised half way through the race my tyres were at 55psi or so.
I do think worries about tyre pressures are generally over-rated!
And on that, for the OP, it's possible that it's the composition of the white line's themselves that are getting a bit slipper as they get hotter.
However, you could always try running your bike at a colder time and seeing what pressure your tyres are when 'hot' - then ride at a hot time and set them to the same pressure.
robbieguy2003
PostPosted: 23:06 - 03 Jun 2010    Post subject: Reply with quote
I cant believe no one has called this guy a bastard, solely on the fact he wont see rain till november! Laughing
On another note, i'd drop a few PSI out of each, maybe 3 or 4 to start, see how it feels and go up down. If you're making changes though, try and do one thing at a time, then you can get a measure or feel for the change.
Swapping lots of stuff at the same time wont help work out what does/doesn't work.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
Acemastr
PostPosted: 06:31 - 04 Jun 2010    Post subject: Reply with quote
Throwing this one out there, 34c air temp must be close to 45c road temp? painted white lines/tar/asphalt are going to start melting at that temp. Even my stand dug into the ground the other day when it was 20c here.
2016 Toyota Tacoma Limited
DrDonnyBrago
PostPosted: 06:58 - 04 Jun 2010    Post subject: Reply with quote
I'd just drop 2 or 3 psi out of each.
IMO though regardless of what it says in the book you KNOW when it is all working properly, if the bike feels right then that is enough Thumbs Up .
c-m
PostPosted: 07:20 - 04 Jun 2010    Post subject: Reply with quote
Hang on... doesn't he want to increase tyre pressure? As that will lead to the temperature lowering.
I thought the issue is that the tyres are getting too hot? Decreasing pressures will see them get hotter.
Dibble
PostPosted: 07:48 - 04 Jun 2010    Post subject: Reply with quote
p1*V1/T1=p2*V2/T2
p=pressure
V=volume
t=temp.
If we take the volume to be constant-it isn't as the tyre is elastic, and use psi for ease
p1/t1=p2/t2
p1=42psi
t1=288k (Kelvin in the uk-15celsius)
p2=x
t2=307k
42/288=p2/307
p2=307(42/288)
p2=44.7psi
So if you set your "cold" pressure in the UK at 42 psi shipped the bike to Cyprus and measured the pressure would be 44.7psi.
You would need to know the particular characteristics of the tyre in regard to Black body Radiation to work out the different pressures at operating temp to find out if it actually runs at a different temp/pressure. Very Happy
Suntan Sid
PostPosted: 07:49 - 04 Jun 2010    Post subject: Reply with quote
I can only apologise, profusely for the climatic conditions here, but hey, it's a dirty job and someone's gotta do it.
My logic is working like this:-
I assumed the tyres were sliding across the white lines because, with the road temperature being so high, this was heating up the tyres and the air inside them thus causing greater pressure and making the tyre a lot harder, making it much easier for the tyres to slide.
Therefore if I was to lower the tyre pressures, to start with, maybe they would reach the correct air pressure during the ride.
I hadn't actually thought about the tyre, (carcass), temperatures being affected by lower pressures, with the, slightly larger contact area resulting in more heat into the tyre.
I'll try losing a few pounds pressure before I start this weekend.
Slightly off topic, but as well as the weather over here, bikes don't need an MOT, so anything goes really, and plod are not allowed to chase bikes!
The icing on the cake, the few speed cameras that they had here were all removed after a contractual dispute with the suppliers, coo-oo-ool!
The only downside, really, is the standard of driving here is truly awful, the locals seem to think that hanging a set of worry beads from the rear view mirror gives them some kind of religious force field around their vehicle, rendering them indestructible. Oh and jumping red lights is an olympic sport here!
The last post was made 16 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 71.71 Kb
