Cleaning out a petrol tank
Misc
PostPosted: 11:29 - 04 Jun 2010    Post subject: Cleaning out a petrol tank Reply with quote
Got mine off & drained at the moment & have noticed particles floating around when there was petrol in there. What's the best (money free) way to give it a good rinse out & get rid of the crap inside please?
Cheers.
Chris750
PostPosted: 11:54 - 04 Jun 2010    Post subject: Reply with quote
Personally I would rinse it out with a bit of fuel.
Do it a few times giving it a good shake until you don't get any bits coming out.
Misc
PostPosted: 11:59 - 04 Jun 2010    Post subject: Reply with quote
Cheers, what side should i be draining it from? The petrol cap or the fuel tap?
I gave it a good shake it the other day & drained the fuel but none of the crap came out, think the fuel tap is too small.
Bit of a silly question but where's the best place to drain petrol without it going everywhere if i did drain from the cap side?
Quote Me Happy
PostPosted: 12:10 - 04 Jun 2010    Post subject: Reply with quote
Into a bucket?
Maybe use a filter to catch all the bits so you can reuse the petrol for more rinsing?
The Artist
PostPosted: 12:19 - 04 Jun 2010    Post subject: Reply with quote
I use small stones. Not very small, make sure they are all at least pea size so easy to get out, put some petrol in there with the stones and shake about, this will scrape any crap off the inside of the tank.
Then get them out and use a hose pipe to completely empty it of debris then leave the tank out in this hot sun for a few hours to properly dry.
Win
PostPosted: 12:32 - 04 Jun 2010    Post subject: Reply with quote
Win
Easier to use nuts on a piece of string tied in a loop, that way you can fish the nuts out much easier than trying to get lots of stones out.
In this weather I'd do what Allymoss said and rinse it out with a hose pipe. It will dry in no time in the sun.
If it's rusty, I'd use electrolysis.
Misc
PostPosted: 12:35 - 04 Jun 2010    Post subject: Reply with quote
Win
Cheers. Will give both a go.
The Artist
PostPosted: 12:40 - 04 Jun 2010    Post subject: Reply with quote
True that lots of nuts on string is good and easier.
Misc
PostPosted: 12:46 - 04 Jun 2010    Post subject: Reply with quote
Will use ms51ves3 string method a try. Thumbs Up
Thanks all.
Misc
PostPosted: 00:33 - 17 Jun 2010    Post subject: Reply with quote
Sorry for the bump but today i got a good look inside the tank & it wasn't rust, more like debris or dirt & random crap. Not much but can clearly see them in the tank.
I tried shaking the tank hard with petrol in it & then emptying but the debris is still there.
Any other suggestions? Is there a very cheap fluid i can use to fill the tank to the brim & empty it & repeat until the crap is out?
gmanxiii
PostPosted: 08:51 - 17 Jun 2010    Post subject: Reply with quote
I'm looking to restore a tank at the moment and found various suggestions on cleaning one being to use phosphoric acid or equivalent industrial cleaner. However you want to be careful as some may leave residue that will end up being mixed up with your fuel. Also its pretty nasty stuff and I think it may be fairly difficult to get hold of. What is generally recommended is the POR15 kits which im looking to use to derust and seal my tank and one of the items in the kit is a Marine cleaner which removes most crap and residue and is available on its own at 9quid a bottle.
kit
Marine cleaner on its own
Heres a guide on how to use it.
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
PostPosted: 11:07 - 17 Jun 2010    Post subject: Reply with quote
Let the tank dry and then tip it upside down. Shake it about a lot to try and get the crap out of the filler. It takes a while but I did this with my TZR tank.
Bishbash
PostPosted: 11:35 - 17 Jun 2010    Post subject: Reply with quote
I used brake cleaner and an air gun to blast on out, works a treat. After the brake cleaner going in there though, give it a rinse out with fuel Wink
alun111
PostPosted: 11:53 - 17 Jun 2010    Post subject: Reply with quote
Have you taken the fuel tap off? (Might have missed that bit) I would then use fuel (you can re-use it if you filter it before putting it back in- so does this between each flush too)
stirlinggaz
PostPosted: 13:07 - 17 Jun 2010    Post subject: Reply with quote
aqnother vote for air line.
give it a good rinse out using the "small nuts on a string & some fuel method", then give it a good blast with compressed air.
just done 2 mito petrol tanks using the very same method.
then fit an in-line fuel filter, to catch anything else.
if you dont have access to an air-line/compressor then one of the tank sealing products like petseal or the por stuff mentioned above, are very good & should stop any further rusting.
cheers,
GAZ
ZRX61
Victor Meldrew
PostPosted: 19:46 - 17 Jun 2010    Post subject: Reply with quote
Take the tap off, the in-tank filter is stopping the crap coming out..
Misc
PostPosted: 22:45 - 17 Jun 2010    Post subject: Re: Cleaning out a petrol tank Reply with quote
Thanks everyone above, very helpful but when with the 'tap off' route.
I took the tap off & flushed it that way (thanks) not sure why i didn't think of it before, i've had the tap of at least 3 times the past few weeks. The crap seemed to come out, little bits of dirt & other bits of crap.
Only had a tiny bit of fuel so couldn't give it a good shake but will give it another go.
The last post was made 15 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.27 Sec - Server Load: 2.52 - MySQL Queries: 13 - Page Size: 91.95 Kb
