v twin single carb querrys
hmmmnz
PostPosted: 12:38 - 04 Jun 2010    Post subject: v twin single carb querrys Reply with quote
ok say i was to go from a twin carb to single carb,
would i need to get a carb that would work or the equiv single cylinder
eg if the bike was a 650cc each cylinder is 325cc
would i just need a carb that would power the single 325cc as they are sucking in at different times,
or would i need to go for a larger carb??
the humans are dead
I kick arse for the lord
PostPosted: 12:53 - 04 Jun 2010    Post subject: Reply with quote
Useless answer coming up. Somewhere between the 2 I suspect (and think there would be some overlap on a proper V twin depending on exact firing order, but don't know with a Honda style dual crankpin). But the useful range of carb sizes is pretty large anyway.
Single carb on a V twin is likely to result in a quite awful intake manifold though.
Robby
Dirty Old Man
PostPosted: 13:04 - 04 Jun 2010    Post subject: Reply with quote
Depends which way round the cylinders are for inlet manifold complexity.
From my own looking around in this area, the CB250RSA is a 250cc single that runs a 26mm carb. The CB two-fifty is a 250cc twin that runs the same (or very similar) 26mm carb feeding both cylinders.
The CB250RSA is quoted at 27hp. The CB two-fifty is quoted at around 20hp.
So I would do the same as Keith suggested and go for something in the middle. For simplicity, you could find a single carb Harley with the same torque output you're after and use a similar carb. Should help estimate the jetting as well.
I have heard of a guy fitting a carb from a mini to a 550/4 with a homemade inlet manifold. He achieved similar performance, but far better economy. No pissing around with balancing either.
Ichy
PostPosted: 13:37 - 04 Jun 2010    Post subject: Reply with quote
You should be able to use one of the standard carbs but your going to have to mess with the jetting and needle height.
All my experience is based around the '87 XV1000 I owned. OEM was a hitachi and it was next to impossible to get spares. If you changed the filter or exhaust then you would need to drill the original pilot jet and bang some washers in there, not very practical.
Originally I fitted one of the OEM carbs and it ran fine with a bit of tweaking, more torque low down but less top end. Changed it to a 42mm Mikuni with an accelerator pump and it was much better.
Might be worth you searching for P901 on viragotech.com. May not be specific to your bike but there is lots of discussions around manifold design including making them out of PVC pipe.
hmmmnz
PostPosted: 14:39 - 04 Jun 2010    Post subject: Reply with quote
ok:D
the bike is a xz400 it runs extremely oddball 34mm down draft carbs
with no floats and an accelerator pump,
the 550 version also has 34mm carbs with slightly different jetting
and i don't think the size of these carbs relate to other types of downdrafts fitted to other v twins ect
i want to get rid of these insults to the gods, and chuck a single cv type downdraft in its place, if all else fails, 2 cv downdrafts
the humans are dead
cb1rocket
PostPosted: 15:37 - 04 Jun 2010    Post subject: Reply with quote
Going from a twin to a single carb would result in loss of power UNLESS you had a massive carb on it!
Why on earth would you want to that anyway?
Gotta be a reason for that surely?
Ichy
PostPosted: 16:00 - 04 Jun 2010    Post subject: Reply with quote
A massive carb could be worse due to the venturi effect.
For a bike sticking out 60HP you would want a carb between 32 and 38mm. A bigger carb might give more power at the top end but it relies on the ability of the engine and any mods that have been done. A smaller carb will accelerate faster. Something like a 36mm should be a good starting point.
For jetting a good rule of thumb is 10% change in size for each mm difference in carb size.
hmmmnz
PostPosted: 16:04 - 04 Jun 2010    Post subject: Reply with quote
my mz500 only has a 34mm carb, and guys reckon the rotax lump runs better with a 32mm carb (obviously venturi effect)
i might see if i can get some carbs off a vfr
and see how i get on,
cheers for the advice lads,
most appreciated Thumbs Up
the humans are dead
temeluchus
PostPosted: 16:30 - 04 Jun 2010    Post subject: Reply with quote
the xz400/550 runs solex carbs just sp ypu know.
If you want to run a gingle carb setup, assuming there is no intake overlap (like most japanese vtwins, XZ included) you are correct, the choke size of the carb should suit the size of one cylinider.
for example on a friends mt11, we made a single carb manifold using one of the original two carbs. The bike ran fine. Someone in the US makes manifolds for old Z750/1000/1100s and suzuki GS.
Single carbing wont be a good idea on high revving high horsepower engines but on lower power engines it should work ok.
The trick is getting the inlets to each cylinder the same length.
Ichy
PostPosted: 16:47 - 04 Jun 2010    Post subject: Reply with quote
I wouldn't mind trying it on my GS500, just for the hell of it. Got to be easier than the XV.
hmmmnz
PostPosted: 22:33 - 04 Jun 2010    Post subject: Reply with quote
Temeluchus wrote:
the xz400/550 runs solex carbs just sp you know.
if the xz ran solex carbs i'd be a happy man,
the fact is they run Mikuni BD 34's and the only thing similar about them and solex carbs is that they are down drafts,
the mikuni's are a completely different animal, and far more complicated than solex carb
the humans are dead
temeluchus
PostPosted: 23:11 - 04 Jun 2010    Post subject: Reply with quote
my bad. Copies of solex carbs. Ahem.
hondapartsman
PostPosted: 08:13 - 05 Jun 2010    Post subject: Reply with quote
Not on v twins but I've heard of people converting something like a Norton Commando to a single carb and just using one of the original carbs. I would say it was a good point to start from then if you need to get something a bit bigger you could.
In the end all comes back to the beginning
The last post was made 16 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 80.49 Kb
