Slight Overinflation of front tyre - big difference!
Cigaro
PostPosted: 16:50 - 04 Jun 2010    Post subject: Slight Overinflation of front tyre - big difference! Reply with quote
How sensitive should my bike be to tyre pressures?
At 25psi it feels just right. The other day I overinflated to about 28 and it felt skittish and didn't want to go round corners.
Is this normal or does it point to something wrong?
SamJL
PostPosted: 16:56 - 04 Jun 2010    Post subject: Reply with quote
Very much depends on what tyre your running, and the temperature outside, but most tyres are run at around 30 - 35psi anyway.
2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX Very Happy
Cigaro
PostPosted: 16:58 - 04 Jun 2010    Post subject: Reply with quote
Pirelli City Demons. Just didn't feel nice at all running at 28 (having said that I also used a petrol station pump rather than a digital gauge and footpump so may be a few PSI more anyway...)
Luke_Retrofly
Silly Lesbian
PostPosted: 17:02 - 04 Jun 2010    Post subject: Reply with quote
Sounds like its more in your head than the actaul tyre, I can image 3 psi making very little difference.
I'm unable to tell soometimes up to 10 pis difference Razz
Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want!
SamJL
PostPosted: 17:07 - 04 Jun 2010    Post subject: Reply with quote
The front end on my Power Pures did feel different at 35psi over 32psi, but I find tyre pressures seem to effect these Michelin's alot more then my Pierelli Corsa III's I had on before, the back end seem to brake away a bit sooner aswell. But to be honest, 25psi is quite low anyway, I can't see taking them up to only 28psi is going to make a negative effect. If your not happy just take them back down to 25psi!
2009 CBR1000RR
2004 KTM 200SX
bEN_
PostPosted: 17:10 - 04 Jun 2010    Post subject: Reply with quote
I can tell if i make small changes, mainly on the front as it's changing the profile of the tyre abit, if i run anything below 30 and it's not a warm day turn in feels sluggish and the bike feels crap imo.
course it could just be in my head but meh Laughing
2010 Ducati 848 Dark
Lamp Post Enthusiast
PostPosted: 17:16 - 04 Jun 2010    Post subject: Reply with quote
25psi is the correct figure for the GN250 front tyre.
Being a cross ply it will likely need different pressures and respond rather differently to a radial.
Luke_Retrofly
Silly Lesbian
PostPosted: 17:18 - 04 Jun 2010    Post subject: Reply with quote
lol you guys are probably more in tune we your bikes than I am Laughing
Same goes with suspension etc, I couldnt tell if it was soft/hard/saggy/spongy. I just ride a bike until I get to scared to go any faster Razz
69.9mph
PostPosted: 17:19 - 04 Jun 2010    Post subject: Reply with quote
Probably need to get your suspension sorted then Wink
Luke_Retrofly
Silly Lesbian
PostPosted: 17:20 - 04 Jun 2010    Post subject: Reply with quote
Read my 2nd post Laughing
edit> wait you changed the quote, i dont get it......
The Artist
PostPosted: 17:31 - 04 Jun 2010    Post subject: Reply with quote
On tyre pressues, my manual says 24 and 28 but I am now running Pirelli city demons so should I up the pressures or do I just play around with what feels right?
tutton
PostPosted: 23:10 - 04 Jun 2010    Post subject: Reply with quote
Apparently from mcn or something similar i read about bike maintainance is 4PSi is enough of a pressure change to alter the handling of the bike enough to be noticeable!
PostPosted: 00:03 - 05 Jun 2010    Post subject: Reply with quote
Wasn't the front on your R6 down to 7psi when I rode it and noticed it felt a bit weird? Smile
Stelmer
PostPosted: 00:12 - 05 Jun 2010    Post subject: Reply with quote
I got told that 28R 25F for my GSX550 was too low and that is why the tyres lasted less than 5000 miles. They were BT45's.
The back one was squared, my fault for using motorways but the front tread was starting to crack and stick out in the parts that came from the centre of the tyre.
Anyway, the garage said to put 42R 36F. Not risking blowouts, I lowered it to 36R 34F and the bike handled well. I am keeping an eye on the back one as the tread pattern is that which will start to seperate from the tyre as it wears.
PostPosted: 00:14 - 05 Jun 2010    Post subject: Reply with quote
Got any pictures of when it did happen?
Danny was describing a very similar thing on his K75 to me today.
Pie-Roe
PostPosted: 00:21 - 05 Jun 2010    Post subject: Reply with quote
Why would 42 be risking a blowout? I was running racetech k1s and supercorsas on my rf900 at 38 and 44psi, made the turn in much better.
Pyro
Stelmer
PostPosted: 00:25 - 05 Jun 2010    Post subject: Reply with quote
Didn't get any images of it, sorry. I've had a look through my old pics and it doesn't show on them.
L4Isoside
PostPosted: 00:51 - 05 Jun 2010    Post subject: Reply with quote
i had both tyres slightly over inflated when warm
made the bike feel shit. after adjustment.. was all good again! Razz
Alexio
PostPosted: 02:38 - 05 Jun 2010    Post subject: Reply with quote
I've had both of my tires at 35 / 40PSI before and I'm happy to report it didn't feel any different even though far above what they were supposed to be. That said, this is a CG, so what I've just said is quite null and void what it comes to handling.
I did however give me some extra MPG and possibly speed Mr. Green
mooserx
PostPosted: 06:54 - 05 Jun 2010    Post subject: Reply with quote
On the cbr, I used to use 36f 42r, but found that just a couple extra psi in the front madse the bike turn in better, maybe it was in my head but i'm sure it made a difference.
c-m
PostPosted: 10:59 - 05 Jun 2010    Post subject: Reply with quote
Aren't pretty much all modernish sportsbikes 36F 42R for the road?
This is what people always recommend for me on the ZX9
Rob W
PostPosted: 11:03 - 05 Jun 2010    Post subject: Reply with quote
I'm the same. Recommended pressures are 36F/42R, but I run then at 38/44, just feels a bit better for me.
skatefreak
PostPosted: 11:08 - 05 Jun 2010    Post subject: Reply with quote
Haha,
when i first rode my NSR, (straight to the petrol station to pump up the tires i might add) the front was sporting a hefty 14psi Shocked
colourful!
-Jvr
serlant
PostPosted: 09:53 - 06 Jun 2010    Post subject: Reply with quote
Somewhat like this? curious as to wether it would pass an mot like this?
https://i191.photobucket.com/albums/z170/serlant/26052010064.jpg?t=1275814255
c-m
PostPosted: 09:57 - 06 Jun 2010    Post subject: Reply with quote
You'd get away with that on an mot.
They are more concerned with cracks in the sidewalls.
The last post was made 16 years, 93 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 126.93 Kb
