Suzuki GS500 2005 Chain replacement
dx90
PostPosted: 08:31 - 08 Jun 2010    Post subject: Suzuki GS500 2005 Chain replacement Reply with quote
Anyone know the correct chain length to go on my GS500 K5 2005?
I have seen a set on Ebay called JT 520 X112 CHAIN for my bike but I thought the length was 110 links and not the 112 on the one that is being sold for my bike.
Also does anyone know if the JT chains and sockets are any good?
Thanks
dx90
PostPosted: 09:36 - 08 Jun 2010    Post subject: Reply with quote
I think that the K5 use's a 520 110 links. Can anyone confirm this please?
Gazdaman
I did a trackday!!!
PostPosted: 10:13 - 08 Jun 2010    Post subject: Reply with quote
Just order one from eBay specifying your make, model and year. Like in the eBay link at the bottom of this page.
I seem to remember fitting C&S from a later GS500 onto my 99 bike last year. So I seem to remember them all being the same.
Or... If you really are hell bent on knowing the spec of your chain, go count the number of links on your chain, start at the split link (or soft link) and count until you get back to it.
Gaz
PostPosted: 10:18 - 08 Jun 2010    Post subject: Reply with quote
Just order from B&C express/Busters, then you'll get the correct one if you put your make, model and year in correctly.
dx90
PostPosted: 11:01 - 08 Jun 2010    Post subject: Reply with quote
Just a thought.
On my old chain only some of the centre rollers are seized where the previous owner left the bike standing through the winter not oiled.
Is it possible to rescue this chain and how would I do that?
A new chain looks very expensive.
Thanks
Gazdaman
I did a trackday!!!
PostPosted: 11:04 - 08 Jun 2010    Post subject: Reply with quote
Replace the chain.
When a chain is poorly maintained, it can fall off, or snap. Either of which can easily cause you to come off, or worse, the snapped end of the chain can hit you. And imagine how fast that could be moving!
I don't always replace sprockets when I replace the chain, a chain by itself is only about £30.
But definitely replace the chain.
I have saved an old chain before by leaving it soaking in old engine oil overnight. But it's really not recommended!
Gaz
DrDonnyBrago
PostPosted: 11:21 - 08 Jun 2010    Post subject: Reply with quote
It depends how bad the chain is, you can free up links by moving them back and forth and cleaning them up with a bucket of paraffin - chances are though if it has got that far then it is probably worth replacing.
If you order one two links too long then just shorten it two links when you fit it Thumbs Up .
Most cheap chain tools will both break and join chains, meaning you can remove a few links and then fit the new masterlink.
I got one for £20 from www.bikespeeduk.com, I had to widen two of the holes on one of the attachments but it was otherwise great value Thumbs Up .
dx90
PostPosted: 12:21 - 08 Jun 2010    Post subject: Reply with quote
In the user manual they recommend a DID 520VM 110 links with O ring.
It's my sons bike, so I will go with a new chain. What is a good cheap chain to buy for this bike or do you recommend I stick with the one in the user manual?
Thanks
Gazdaman
I did a trackday!!!
PostPosted: 12:24 - 08 Jun 2010    Post subject: Reply with quote
You buy cheap with C&S, you buy twice.
But buying this:
https://cgi.ebay.co.uk/SUZUKI-GS500-GS-500-E-CHAIN-KIT-HEAVY-DUTY-/110538991066?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item19bca325da#ht_3398wt_911
Would be better than using a knackered old seized up chain.
But for something with a bit of a longer lifespan, and a bit more quality I'd be going for:
https://cgi.ebay.co.uk/SUZUKI-GS500-99-06-DID-X-RING-CHAIN-AND-SPROCKET-KIT-/280379148581?cmd=ViewItem&pt=UK_Motorcycle_Parts&hash=item4147e64925#ht_1403wt_879
It's still inexpensive, but it's a reputable brand, and spec.
Cheap chains stretch, and will need replacing sooner than a more expensive chain. It's a bit of a false economy.
Gaz
Robby
Dirty Old Man
PostPosted: 12:43 - 08 Jun 2010    Post subject: Reply with quote
Gaz
But that's worthwhile when a chain costs £16.50 and a set of sprockets about a tenner.
Old bikes FTW.
Gazdaman
I did a trackday!!!
PostPosted: 12:47 - 08 Jun 2010    Post subject: Reply with quote
Hey I'm not here to preach.
My last chain was actually branded 'best quality'.
I'm pretty sure I stretched it opening the packet.
Gaz
dx90
PostPosted: 13:04 - 08 Jun 2010    Post subject: Reply with quote
Just had a look at the chain on the bike and there isn't a removable link. Do I need a special tool to remove it and do I need a new one to put the new chain back on and how easy is it to do?
Thanks
temeluchus
PostPosted: 13:12 - 08 Jun 2010    Post subject: Reply with quote
Thanks
You can just cut the chain off with a grinder.
When you get a new chain, these days, you usually get a "soft" link that needs a chain rivetter to fit and a "Clip" link that can be fitted with a flat blad screwdriver. Soft link is more secure, clip is easier to fit.
DrDonnyBrago
PostPosted: 13:38 - 08 Jun 2010    Post subject: Reply with quote
Use a dremel to grind the head off of a link then use a chain breaker to push the pin out OR just hacksaw the old chain in half - it really doesn't matter, the chain is getting binned anyway Thumbs Up .
Assemble your new master link and use a chain rivetter to press on the link plate and then stake the rivets on the soft link.
Did my first C+S swap a few weekends ago, took me about an hour and a half and that included lots of cleaning. It's very easy.
dx90
PostPosted: 13:48 - 08 Jun 2010    Post subject: Reply with quote
Great advice.
What about this one,
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260587029499&_trksid=p2759.l1259
I will need to buy a tool anyway and they seem to be best part of £25 to buy.
Thanks
Gazdaman
I did a trackday!!!
PostPosted: 13:51 - 08 Jun 2010    Post subject: Reply with quote
That's not bad, those tools are always worth having the garage. I paid £50 for my one.
£100 for full C&S and the tool including postage is alright in my book.
Depends if you have any mates you could borrow the tool from locally. Or you could order a split link, fit that. Ride to a bike shop and have them rivet the soft link. Unlikely to save much money though.
Gaz
temeluchus
PostPosted: 14:12 - 08 Jun 2010    Post subject: Reply with quote
I've almost always used the clip link and never had a failure, including on some powerful machines-FJ1200, GSXR1100, GPz1100. But I have always bought the correct grade of chain and not cheapy. If I cant afford super dooper X ring whatever, DID NZ plain jane chain is good quality. The 530 is in fact stronger than most of the 0/x ring chains in tensile strength. As I run a loobman on chain bikes they last just fine.
The last post was made 16 years, 88 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.29 - MySQL Queries: 16 - Page Size: 99.31 Kb
