| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 10:54 - 08 Jun 2010 Post subject: KLX 250 - Noisy tappets, or about-to-snap cam chain? |
Got a KLX250 recently, and it's got quite noisy over the last couple of days. Once it's hot, there's a sharp metallicy tap all the time, which sounds to me that it's tappets or cam chain. Not sure which, tbh.
Also, it's impossible to rev over around 7 - 9k revs (I'm guessing as there's no rev counter), even on full throttle it seems to be limited and won't rev beyond that. I'm having problems with the carb at the moment as well, (but I'm sure there's enough fuel getting through on full gas) so I'm not sure if that's related, or if it's just the tappets or cam that won't let it rev freely.
Before I take the cover off, can anyone advise what it's most likely to be? I don't want to shell out on a new cam chain if I can avoid it, but if it is likely to be that, I'd rather get a new one before I take the cover off.
Lastly, until I get a manual for it, I'm not sure whether I can just adjust the tappets (easy and cheap) or if I have to bugger about with shims. Anyone know which system it uses..?
It's a 1994 KLX250E, btw.
Cheers!  ____________________ A Guide To Powerbands |
| Gazdaman |
 Gazdaman I did a trackday!!!
| Mr Hammers |
 Posted: 11:22 - 08 Jun 2010 Post subject: |
Tried the screwdriver trick already, but while I can hear a difference, depending on where I put it, I still don't know enough to be able to tell what it is I'm actually hearing..
Oil level is ok, if slightly under the mark.
Would yours rev all the way from 1k to 'screaming', btw? Or would it feel as though it was limited at around 7-9k, and feel a bit sluggish when riding? (No experience of mid capacity single 4 strokes, so I'm not sure what I should be expecting..) ____________________ A Guide To Powerbands |
| Gazdaman |
| Mr Hammers |
| Gazdaman |
| Mr Hammers |
 Posted: 12:08 - 08 Jun 2010 Post subject: |
I do have a tester, but it's for the bigger plugs and not this tiny one. I've been trying to find an adapter for it, but no joy yet. But still, I'm hoping it's not that too  ____________________ A Guide To Powerbands |
| Gazdaman |
| Raffles |
 Raffles World Chat Champion
| Robby |
 Robby Dirty Old Man
| Gazdaman |
| Mr Hammers |
 Posted: 16:07 - 08 Jun 2010 Post subject: |
Pretty sure it doesn't have points, as it has a leccy box unit on it.
Will check the valve clearances at the weekend, hopefully it's just that (looks like it's a shim job then, if Raffles's was shims ) or it's just the cam chain tensioner that needs looking at.
Although saying that, just rode back to work and it seems to have gone quieter..maybe the auto adjust has kicked in..? It's still pretty sluggish though.
I'll keep looking to see if I can find an adapter for the compression tester in the meantime too.
Anyway, cheers all, much appreciated  ____________________ A Guide To Powerbands |
| Grazoid |
 Grazoid Scooby Slapper
| Grazoid |
| Mr Hammers |
 Posted: 17:33 - 09 Jun 2010 Post subject: |
| Grazoid wrote: | Okay first step is to check valve clearances... if the ignition side has closed up you will get crap starting and it will run like a slug. |
Starting isn't too bad usually, but it does run like a slug definitely.
| Quote: | Next is cam chain tension. You can check this when checking the tappets. You should not be able to raise the chain off the sprocket teeth.
Next step is the tensioner. Make sure you are at the timing mark and whip the tensioner off. Check for wear and if it is working correctly ten either replace with a new one or re-tension and re-fit.
Check. Will be doing all that this weekend, I hope. By timing mark, you mean the 'T', which indicates TDC, is that right?
| Quote: | Then check your air filter. |
I tried it without the filter on, and it's everso slightly perkier, as I expected, but still down on grunt. Does sound a lot better though, I love induction roar
| Quote: | Also does the noise go away if you pull the clutch in ? If so then check your clutch plates for wear. |
No, it's at its noisiest just riding along, comes from inside the head/block, and doesn't go away with the clutch pulled in. In fact, the clutch is one of the few things that seems to actually work properly
Cheers, Grazoid. ____________________ A Guide To Powerbands |
| Raffles |
| Mr Hammers |
| ben_wheely |
 ben_wheely Trackday Trickster
 Posted: 13:12 - 11 Jun 2010 Post subject: |
I have this problem with my wr250 at the moment too.
I don't have a loss of performance though, just a unusual noise coming from the engine block (more from the exhaust side).
Its probally due for the valve clearences to be checked, just hope its nothing expensive.
To the OP let us know how you get on  ____________________ Rides: '05 Yammy WR290-F |
The last post was made 16 years, 61 days ago. Instead of replying here, would creating a new thread be more useful? |
