Wobbly when cornering
Bubbs
PostPosted: 11:03 - 11 Jun 2010    Post subject: Wobbly when cornering Reply with quote
bore da pawb,
I'm having issues with wobble while I'm cornering. Now I can see that my front is slightly squared off so I know I need to change it but is this squaring of the wheel causing all the wobbles?
If not then what could it be?
It only seems to happened when I'm cornering a bit and is fine when I'm going straight.
woll
PostPosted: 11:12 - 11 Jun 2010    Post subject: Reply with quote
Have you checked wheel bearings?
Bubbs
PostPosted: 11:28 - 11 Jun 2010    Post subject: Reply with quote
Not checked anything yet mate, only noticed it today. What do I need to do to check them?
Walloper
PostPosted: 11:33 - 11 Jun 2010    Post subject: Reply with quote
Squaring of the tyre will cause massive handling problems. Wobble could be a symptom of that.
Tyre pressure too high or too low. 10/15PSI would be enough to upset tyre performance.
You live in an old town with 'pituresque' cobbled streets... Laughing
Paxovasa
PostPosted: 11:40 - 11 Jun 2010    Post subject: Reply with quote
Does it happen when braking or accelerating?
Kris
PostPosted: 11:42 - 11 Jun 2010    Post subject: Reply with quote
Badly squared off tyres cause all sorts of weirdness when cornering. The front tyre develops ridges which can mean it feels sluggish to turn initially then all of a sudden drops off the edge rapidly.
Combine this with a squared rear tyre and cornering can feel erm... interesting! Shocked When you go to change the tyres and lift the wheel off the ground it's always a good idea to check the wheel for bearing play too. It should only rotate freely on the spindle, no sideways movement should be possible. Karma
www.prisonplanet.com
Bubbs
PostPosted: 12:18 - 11 Jun 2010    Post subject: Reply with quote
Ah right yeah I'll check for play when the rain decides to subside. It seems to only get bumpy and odd when cornering at lower speeds. Just turning slightly feels bumpy.
The last post was made 16 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 52.46 Kb
