Hydraulic brake line advice required
Dan79
PostPosted: 21:28 - 15 Jun 2010    Post subject: Hydraulic brake line advice required Reply with quote
My Honda Magna needs a new front brake line fitted.
How crucial to the operation of the system is the angle of the new banjo bolts that are fitted ? Will any angle do, so long as the line does not kink or abrade other components ? Common sense says yes any will do, but I am pretty much a novice when it comes to dealing with hydraulic brake systems first hand, any advice welcome.
Previous bikes - 1984 Honda VF500 (FII) Interceptor and 1990 Yamaha RXS100
Current bikes - 1984 Honda VF500 (V30) Magna
Walloper
PostPosted: 22:11 - 15 Jun 2010    Post subject: Reply with quote
There should be two lugs cast into the master cylinder and caliper to guide the stem of the banjo. Anywhere between the lugs is good.
You should be using new washers too. These are compression seals that form a metal to metal seal by deforming and conforming to the surfaces between the bolt, banjo and housing.
Before you hoi it all up tight you should check the routing doesn't allow fouling, twists or kinks in the lines. Use the clamps they are designed to prvent chaffing of hose and damage to frame or the hose being trapped between moving parts.
Dazbo666
PostPosted: 13:37 - 17 Jun 2010    Post subject: Reply with quote
Walloper beat me to it. I've recently upgraded the lines on the Bandit ... +1 with Walloper
Word of the day : DILLIGAF
The last post was made 15 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 35.63 Kb
