my dt will not rev properly and cuts out please help me
dudejb46
PostPosted: 20:38 - 16 Jun 2010    Post subject: my dt will not rev properly and cuts out please help me Reply with quote
hi guys,
i have a 98 dtr which is giving me jip
i ran it on reserve for about 10 miles and towards the end off that it started spluttering and not revving out like normal and somtimes bog and cut out as if i was out of petrol.
i filled up thinking this was my problem but it carried on
i have cleaned the carb out + main jet
changed the sparky new one was a 9s, died straight away so now has the old 8s with decent spark emitting.
it does run rich on oil but it has done for last 500 miles not a problem.
when it goes to bog out if i put the choke on it tends to then rev again but still not fully as normal
please help me any one Smile
2002 zip 2002 bandit project 2004 fzs1000 2009 883r
0l0dom0l0
PostPosted: 21:42 - 16 Jun 2010    Post subject: Reply with quote
sounds like its too lean. by leaving on the reserve you will have probally pulled a load of gunk from the bottom of the tank through. i would reconmend that you change the fuel filter, and check that the fuel lines are okay.
dudejb46
PostPosted: 21:53 - 16 Jun 2010    Post subject: Reply with quote
thank you for your reply
no filter on this bike in tap or pipe so im lost there and i have blown through the pipe
The last post was made 15 years, 234 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 40.82 Kb
