New chain tight spots
DrDonnyBrago
PostPosted: 08:42 - 17 Jun 2010    Post subject: New chain tight spots Reply with quote
Hi, fitted a new chain and sprockets about 100 miles ago, noticed when I was setting the chain tension that one part was slightly tighter (about 10mm of slack difference) than another part.
I assumed it would stretch even after a few miles of riding but the difference still exists. Is it normal to have a mild tight spot on a brand new chain?
Paxovasa
PostPosted: 10:08 - 17 Jun 2010    Post subject: Reply with quote
Thats is not normal. The chain may have been stored for a while and so the protective coating may have degraded and due to that a link has become dry.
Try giving it a good lube, but keep a close eye on it Thumbs Up
L4Isoside
PostPosted: 10:13 - 17 Jun 2010    Post subject: Reply with quote
Im pretty certain all chains have slight tight spots (hence why you should adjust them at the tightest spot) 10mm isnt really alot either.
But then again i dont know what it should be like after only 100 miles? But both my ybr and my SV's chains have slight tight spots.
DrDonnyBrago
PostPosted: 14:26 - 17 Jun 2010    Post subject: Reply with quote
Hmmm....
It just seemed wierd for a brand new chain to have a tight spot. I have given it a good oiling before I last went out so it must be something to do with the actual chain. If it has a tight/loose spot now then in 15k miles it might be MUCH more pronounced...
Reckon I should get onto the shop and have a moan?
The last post was made 15 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 38.89 Kb
