Screw / Bolt Extractors
Dazbo666
PostPosted: 13:34 - 17 Jun 2010    Post subject: Screw / Bolt Extractors Reply with quote
I have a couple of rounded allen head bolts that I need to remove, to take the front sprocket cover off the Bandit.
On a previous (non-critical) job, I tried using some of the spiral-type extractors with potentially disasterous consequences... the hardened extractor snapped off inside the head of a bolt.
So, not wanting to repeat the experience I'm looking at some of the alternative designs....
Any recommendations etc on reliable, effective, user friendly options would be welcome!
Word of the day : DILLIGAF
stirlinggaz
PostPosted: 13:45 - 17 Jun 2010    Post subject: Reply with quote
hi,
I have found most of the extractor kits to be a waste of money, often causing more serious problems than a stuck bolt.
nowadays i dont even bother with them.
if the head of the bolts is not flush with its mounting, i will usually cut a slot into the head of the bolt with a dremel & cutting disc attachment.
then attempt to unscrew the bolt with a flat bladed screwdriver or impact driver.
if that fails,or the head is recessed i reach for the cobalt drill,lol
cant remember how many times i've told people this, but they really are a revelatipn!
i got some de-walt drill bit off ebay as a last resort to removing some seized bolts.
the go right through most metals, just drill at a low speed keeping the bit cool & using plenty of cutting oil (i cheat & use some cheap bike oil from pouundland)
i start with the 3mm bit & work up wards until the head of the bolt shears off, letting me remove what im trying to get off, leaving the remainder of the bolt stub protruding.
then i remove the stub with mole grips or a pipe wrench.
if the bolts is, like an exhaust manifolt bolt, i just keep drilling until the bolts spins free. (stepping up through the sizes)
if i go too far, i cut new threads.
cheers,
GAZ
The last post was made 15 years, 225 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 33 Kb
