CBR600FM Clutch
DKH23
PostPosted: 21:59 - 17 Jun 2010    Post subject: CBR600FM Clutch Reply with quote
Hi all,
Started to replace the Clutch on my CBR600FM 1991 this evening.
I'm going along with the haynes manual, but i'm struggling with
finding how tight I need to tighten the 4 springs. There is no
torque setting in the haynes manual. So how do I go about sourcing this?. I put the clutch cover back on and fired the bike up, but as soon as I put it in gear, with the clutch in.. It jolted forward. I'm guessing this is to do with incorrect spring tension?!. Any help on this is appreciated. As I want to get back out on two wheels ASAP! Wink
Paddy Blake
PostPosted: 22:10 - 17 Jun 2010    Post subject: Reply with quote
Did you adjust the cable.
The bolts should be tightened until the plate they go trough is at the alloy
the bolt goes into and then a bit of a turn to lock it tight.
DKH23
PostPosted: 22:15 - 17 Jun 2010    Post subject: Reply with quote
Cheers Paddy.
Do I have to tighten the bolts up till I cant tighten anymore?
As I did this and there was no slack in the springs, So I stopped!
Paddy Blake
PostPosted: 06:05 - 18 Jun 2010    Post subject: Reply with quote
Torque setting will be 12 Nm
Paddy Blake
PostPosted: 06:26 - 18 Jun 2010    Post subject: Reply with quote
Did you leave the plates in oil for a while before you put them in. Question
Tape the lever to the handlebar and leave it over night.
The last post was made 15 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.5 - MySQL Queries: 13 - Page Size: 42.53 Kb
