| oriel dave |
 oriel dave Nova Slayer
| MrJames |
 MrJames Two Stroke Sniffer
 Posted: 00:34 - 12 Jun 2010 Post subject: |
Get the cylinder rebored and fit a slightly oversized piston  |
| evoboy |
 evoboy World Chat Champion
 Posted: 01:10 - 12 Jun 2010 Post subject: |
Might get away with just a hone to the barrel, if there are no deep scores.
Piston and rings defo need replacing and possibly the small end bearing if its been rusty in there. ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| Teflon-Mike |
 Posted: 03:14 - 12 Jun 2010 Post subject: |
| evoboy wrote: | Might get away with just a hone to the barrel, if there are no deep scores.
Piston and rings defo need replacing and possibly the small end bearing if its been rusty in there. |
Honing the bore was my first thought, too, but I had a think about the piston & rings.
First off its an MZ. Second up its a two-smoke. Third up, parts in question are presumed dead anyway...
So what MORE harm could you do?
If you have a honing arm, I'd give it a go. Failing THAt, sounds horid, but east-german tolerences were't exctlt 'precise...
FINE wet & dry, wetted with thin oil. Use a large area and work it evenly round the bore.
Rings susted in the piston gfrooves will be a bugger, BUT, soak in penatrating oil.
See if you can tap the ring-pins out from inside the pistonso the rings can be turned in the groove, and then fiddle & riggle them to see if they loose.
again, fine oiled wet & dry to clean up the ally piston, & gentle attension around the rings might get them free.
If so, remove, clean, and oil-wet & dry on thr rings & the rest of the pistion.
Assemble back up with LOTS of 2-stroke oil to lube it; turn it over gently by hand, plug out to work it through...
THEN pup the plug back in, make sure the points are clean, and give it a kick... see how it goes!
You NEVER KNOW!
These engines are very tolerent of 'brutal' mechanics, and the worst that can hapen is the bores so far gone one of the rings snags and drags gouges down it....
But as its PRESUMED it needs a rebore ANYWAY... that would have been on the cards.
Best case, it works, job sorted for little more than time, patience and bit of sand-paper and old oil!
I'd give it a go! |
| Paddy Blake |
 Posted: 03:38 - 12 Jun 2010 Post subject: |
| Teflon-Mike wrote: | | evoboy wrote: | Might get away with just a hone to the barrel, if there are no deep scores.
You NEVER KNOW!
I'd give it a go! |
Long story short.
Hone the cylinder,heat the piston to get the rings out then sand the piston with wd40 and p120 sand paper. |
| 27cows |
 27cows World Chat Champion
 Posted: 06:43 - 12 Jun 2010 Post subject: |
I've had bores like that. Don't even bother trying to rescue it. Get a rebore and save yourself endless hassle. Besides which, that piston has seen way better days  ____________________ The RXS100: vehicle of choice for Chuck Norris |
 Posted: 07:33 - 12 Jun 2010 Post subject: |
Hard to tell from the pictures if the barrel is rust-pitted. If it is, you need to bore & hone or replce it.
I don't see why spares should be any morer difficult to find than usual. Take a look around for oversize pistons and agood used piston 7 barrel and buy whichever comes up first. ____________________ a.k.a 'Geri'
| temeluchus |
| oriel dave |
| Walloper |
 Walloper Super Spammer
 Posted: 11:25 - 12 Jun 2010 Post subject: |
It looks facked.
But if parts are going to be a problem then it may be worth the effort to clean off all the shite and measure up the bore, piston diameter and ring groove clearances.
It may have been seized only because water got into it.
If you are not sure of history on the beast then it may be worth fannying around first.
If time is an issue and you can source a new o/sized piston and rings then hone/re-bore to new size and ride on.
Yes to crack the engine open and do a thorough overhaul.
There could be skeletons in there you don't know about 'YET'.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| temeluchus |
| 27cows |
| oriel dave |
 Posted: 01:16 - 14 Jun 2010 Post subject: |
The hell with just honing it, you'll never know if the bore is worn past tolerance 'till you get it back. Get it rebored and the next size up piston. Then it's right.
Hand-held honing tools aren't really the right way to hone a bore anyway. To do it properly, you do it with a stone in a boring bar. If it's set up to do that, you may as well have it rebored then honed. It'll be like a new motor then.
Incidentally. If you're splitting it. MZs take standard size wheel bearings as mains, which are cheap and easily obtained.
To re-iterate and add some tips born out of experience. Don't start to strip it unless you have a) An impact driver and b) A clutch puller. The clutch fits on the end of the crank and they are really fucking tight. I've seen people bend 3-leg pullers on them.
When it comes to splitting the cases. Take the bolts out and put the whole thing in the oven until it's "spitting hot". One tap and the crankcase halves will fall apart. Try it cold and you'll land up hammering at it and breaking something when you eventually resort to jamming your biggest screwdriver in the top of the crankcase join and prying it apart.
When you rejoin it, get someone to slowly turn the crank as you tighten the bolts or you'll find it nips up tight and won't turn. If they start to feel resistance, give it a light whack on either end of the crank with a deadblow hammer and carry on as before.
Check the gear lever return spring. If it looks at all ropy, replace it while it's apart. They commonly break, you used to see lots of MZs with a bungee on the gear lever. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Odie |
 Odie World Chat Champion
| MarJay |
 MarJay But it's British!
| oriel dave |
 Posted: 10:00 - 18 Jun 2010 Post subject: |
Sorry for delayed response. Getting oversize piston and taking it in to get rebored.
Thanks for the advice, esp. stinkwheel!  ____________________ Europe Trip 2009 |
| MarJay |
 Posted: 10:09 - 18 Jun 2010 Post subject: |
Well done, you know it makes sense! You should have a nice reliable bike once the work is complete. I love MZ's!  ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
The last post was made 15 years, 336 days ago. Instead of replying here, would creating a new thread be more useful? |
