Connecting PS3 to computer monitor
KLR600
PostPosted: 00:21 - 27 Jun 2010    Post subject: Connecting PS3 to computer monitor Reply with quote
Can it be done? I'm going to uni in September and I'm thinking of ways to downsize, I already have 3 monitors hooked up to my pc so I don't really need a massive CRT TV in the corner of my room as well if I can help it!
<Take Cool Photos!>
colin1
Captain Safety
PostPosted: 00:25 - 27 Jun 2010    Post subject: Reply with quote
you need a widget
https://www.thegametrain.com/products/14716-wii-and-ps3-vga-cable.html
R6Armadillo
PostPosted: 01:12 - 30 Jun 2010    Post subject: Reply with quote
If your monitor has DVI inputs you can use a HDMI to DVI cable similar to this: https://cgi.ebay.co.uk/New-HDMI-Male-DVI-I-24-1-Male-Extension-Cable-1-8M-/160443882801?cmd=ViewItem&pt=UK_Computing_CablesConnectors_RL&hash=item255b335d31#ht_4485wt_1002
I have been using one for a while with a PS3 and 22" Monitor
When Eric eats a banana, an amazing transformation occurs. Eric is Bananaman. Ever alert for the call to action.
colin1
Captain Safety
PostPosted: 20:42 - 30 Jun 2010    Post subject: Reply with quote
thats a better widget than the one i suggested, as DVI is better than VGA
KLR600
PostPosted: 00:12 - 01 Jul 2010    Post subject: Reply with quote
I suspect they're both better than a scart though Laughing
<Take Cool Photos!>
KLR600
PostPosted: 20:08 - 05 Sep 2010    Post subject: Reply with quote
Dragging this back up because I've now moved and managed to hock my TV.
Basically I'm getting really confused with all the connections and stuff. I've got 2 old school CRT monitors and a faulty flat screen LCD that works but if my pc goes into standby mode or stops sending a signal to it it freezes in the off position and you need to unplug it then leave it for a few minutes before it'll work again.
Also I'm a bit confused about the audio as I understand I'll lose the audio if I use the HDMI converter as it only supports 5.1 sound or something?
The sound card on my computer has SPDIF inputs so can I use the HDMI port on the PS3 to output the video then use a different output for the audio?
So I'm wanting to use my PS3 with one of my CRT monitors without losing the sound, anyone help?
BTW - I don't mind unplugging and plugging things back in between using my PC and my PS3 if that makes any difference so I'm not bothered by a permanent set up once kind of thing if that makes any sense. Also, the cheaper the better as I'm a poor student now! Laughing
<Take Cool Photos!>
PostPosted: 22:23 - 05 Sep 2010    Post subject: Reply with quote
Isn't there an external sound port on a PS3? I would check mine but can't be bothered to move 2ft.
colin1
Captain Safety
PostPosted: 22:29 - 05 Sep 2010    Post subject: Reply with quote
ok, i take it back, his widgit is not better, as it doesnt have sound connections mine does
the one i suggested outputs to vga but also has phono connections for left and right stereo sound
Aka Matt
PostPosted: 22:36 - 05 Sep 2010    Post subject: Reply with quote
It doesn't really matter as you can set the ps3 to output sound using the av cable and plug the red/white cables in for sound whilst setting the video to output via hdmi.
Current bike(s): 2016 Tuono 1100 Factory, 1998 Hornet 600
Previous: 1998 YZF600R Thundercat, 2001 Bandit 600, 2002 GSX-R 600 K2, 2011 Tuono R, 2013 Z1000SX
KLR600
PostPosted: 12:40 - 06 Sep 2010    Post subject: Reply with quote
Spellchucker wrote:
It's an old crt monitor, we need to know what connections on the back of them are ... i think ... Thumbs Up Idea
I just had a look on the back of each of my monitors and they only have the power socket and the VGA output like this:
https://img.photobucket.com/albums/v331/serenaur/c00513374.jpg
For sound I have one of these cards in my pc:
https://www.google.co.uk/products/catalog?q=m+audio+2496&um=1&ie=UTF-8&cid=8592815504381270436&ei=08-ETI37OcLCswbt5N2aBQ&sa=X&oi=product_catalog_result&ct=result&resnum=4&ved=0CDcQ8wIwAw&os=tech-specs
I currently have a phono cable going from the phono output of the card to the input of my stereo and generally just listen to everything through headphones.
Am I right in thinking that I all I need then is to get a HDMI to DVI converter doohickey like this?
https://cgi.ebay.co.uk/24K-GOLD-plate-DVI-HDMI-Adapter-Adaptor-Belkin-1080p-/260647358777?pt=UK_Computing_CablesConnectors_RL&hash=item3cafcb1139#ht_2522wt_959
I'd unplug one of my monitors from my pc and plug it into my PS3 via the HDMI socket with the adaptor then using the AV multi out on the PS3 I could just take the audio and route it to my stereo which would totally bypass my PC?
I know the PS3 supports dual audio outputs but not sure if it does so in this way.
Thanks for the help so far Thumbs Up
<Take Cool Photos!>
KLR600
PostPosted: 20:39 - 06 Sep 2010    Post subject: Reply with quote
Spellchucker wrote:
Sorry i can't be of more help, my suggestion should see you right .. Rolling Eyes Thumbs Up Smile
No worries, I ordered one of those DVI to HDMI converter things as it's only £3 so worth a punt I thought. Forgot to mention I already have VGA to DVI adapters on my monitor leads! So I'll see how it works out when it comes in the post and report back.
<Take Cool Photos!>
The last post was made 16 years, 25 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 93.47 Kb
