Am I being Dumb? - SORTED Now with Pilot Sporty Mini Review
herulach
PostPosted: 22:20 - 28 Jun 2010    Post subject: Am I being Dumb? - SORTED Now with Pilot Sporty Mini Review Reply with quote
I'll start by saying I have no idea about motorbike tyres, plenty of stuff about mtb tyres.
Anyway, can I put tubeless tyres on a rim designed for tubes? On an mtb this would work, but motorbikes may well be different.
Tyres are Michelin Pilot Sportys on a YBR 125.
YBR 125>FZS600
neil.
PostPosted: 22:22 - 28 Jun 2010    Post subject: Reply with quote
Fit them with tubes if used with a tube type wheel, that's the way it's meant to be done. Thumbs Up
PostPosted: 22:24 - 28 Jun 2010    Post subject: Reply with quote
Assume you mean with tubes inside the tubeless tyres? If so it can be done although you should use different tubes; heavy duty ones that are more resistant to the rough finish on the inside of tubeless tyres.
doggone
PostPosted: 22:26 - 28 Jun 2010    Post subject: Reply with quote
I think tubeless tyres officially should not be used with tubes in as they behave in ways which can cause the tube to fail.
Not sure if that would equate to MOT fail, can't imagine them wanting to check.
I remember someone I know getting into trouble for having tubes in when riding in Germany - done as a puncture fix.
Edit: what Kickstart said while I was typing..
neil.
PostPosted: 22:30 - 28 Jun 2010    Post subject: Reply with quote
I thought (and read somewhere) that the Pilot Sportys are a bit of an exception - designed to be used on either tubed or tubeless wheels with/without a tube respectively.
kt
PostPosted: 22:41 - 28 Jun 2010    Post subject: Reply with quote
Your rims will probably be stamped "Tubless tyre Applicable" if they are suitable for tubless only.
neil.
PostPosted: 22:51 - 28 Jun 2010    Post subject: Reply with quote
The YBR wheels are definitely for tubed tyres only. Lots of people have used Pilot Sporty's on them (with tubes) and there are many very favourable reports about them (just Google 'YBR Pilot Sporty' etc). Might try them myself but I'm also quite happy with the City Demons. Thumbs Up
herulach
PostPosted: 22:53 - 28 Jun 2010    Post subject: Reply with quote
See thats whats confusing, michelin don't say anything, some places list a tube and a tubeless in the same size and some places just say universal.
Now, need to find someone to fit them, not sure I fancy doing it myself.
YBR 125>FZS600
binge
Emo Kiddy
PostPosted: 22:56 - 28 Jun 2010    Post subject: Reply with quote
I've always ran tubeless tyres with tubes on my Road Legal Supermoto Mini-bike.
I'm not running 1 piece alloy Mag wheels, So I can run tubeless. But before, when I was using spoked wheels, I ran tubes all the time. Never had an issue.
PostPosted: 23:08 - 28 Jun 2010    Post subject: Reply with quote
There are two separate points here - air leakage through the rim and through the tyre.
Tyres for tubes may not work well for various reasons, including that they can leak air through the rubber it's self.
The rim must also be airtight, which tubeless rims are. Rims for tubes aren't generally as the holes for the spokes cause relatively massive holes. You can get a couple of kits which use a smaller bicycle style innertube to seal the main one; if your bike has 18" or bigger rims you could probably get a set of these, though they're quite expensive in the UK - they also act as A 360 degree rim lock, which is excellent for riding rough terrain (I mean up a mountain side, not the pot holed backroad!)
I've also heard of people just thoroughly covering the spokes in silicon with gaffa tape on top and that working.
Personally, I wouldn't bother unless I wanted to run really low pressures (below 10psi).
herulach
PostPosted: 23:20 - 28 Jun 2010    Post subject: Reply with quote
Thats what I've done on my MTB (BMX inner tube split in half and lots off goop).
The wheels are 1 piece, so shouldn't like air that way, but I assume the bead is different? I really should ask a tyre fitter, but if everyone did that where would forums be!
YBR 125>FZS600
Ingah
PostPosted: 23:22 - 28 Jun 2010    Post subject: Reply with quote
I'm sure i remember reading that fitting a tube to tubeless tyres was strongly not recommended due to excessive heat build up.
Regarding the other way around, tubeless tyres are designed to seal tightly/properly, whilst tubed tyres aren't - so if you're trying to get away without a tube this would suggest it might not seal as well/properly. Tubeless tyres also are coated with a "thin airseal liner" that is "designed to grip around anything that punctures so that blowouts are avoided and deflation is slowed" (quoting Haynes Motorcycle Basics Techbook). Obviously this would imply that this is not present in tubed tyres.
-- Ingah
PostPosted: 23:30 - 28 Jun 2010    Post subject: Reply with quote
For dirt tyre types (including road ones), the bead definitely isn't an issue. Expect it's similar for road ones, but can't be sure.
kt
PostPosted: 00:18 - 29 Jun 2010    Post subject: Reply with quote
Op, take great care before you make a decission as there may well be insurance and warranty problems associated with your choice of tyre, just be careful and do your homework first.
Robby
Dirty Old Man
PostPosted: 08:23 - 29 Jun 2010    Post subject: Reply with quote
Why not just fit tubed tyres?
If the bike was designed for tubed tyres, it doesn't need tubeless ones. You can buy pretty good tyres that take tubes, and they're cheap too.
If you fit tubeless tyres with tubes it may work, but you'll spend all of your time overrreacting to every bump and wiggle, thinking that the tube has split and all pressure has suddenly gone.
herulach
PostPosted: 21:05 - 29 Jun 2010    Post subject: Reply with quote
Pilot sportys are widely recognised as the best tyre for this bike, just everywhere lists them as tubeless. Phoned round a couple of places today, and got one of them to ask their supplier, turns out there are two versions, but the tubed one is the one generally stocked, so no problem there.
If anyones looking, cheapest I can find them delivered is 79 delivered from mandp.
Will get tubes from wherever I get them fitted, £20 for the pair seems pretty reasonable.
YBR 125>FZS600
PostPosted: 21:28 - 29 Jun 2010    Post subject: Reply with quote
I recall seeing stamped on a tubeless tyre something like 'Use a tube on tube-type rims'. Might have been a sporty actually coz it wasn't all that long ago.
herulach
PostPosted: 17:43 - 05 Jul 2010    Post subject: Reply with quote
This, tyres came today, and thats what they say on them, panic over.
YBR 125>FZS600
neil.
PostPosted: 18:29 - 05 Jul 2010    Post subject: Reply with quote
Told ya. Thumbs Up Please let us know how you get on with them. Smile
herulach
PostPosted: 18:37 - 05 Jul 2010    Post subject: Reply with quote
They're going on on wednesday, and assuming I get the forks back together (gonna do the seals while I have wheels out) I'll be off out for a bimble later that night.
YBR 125>FZS600
herulach
PostPosted: 20:29 - 08 Jul 2010    Post subject: Reply with quote
Right, after 40/50 mile pootling around in the semi wet conditions, I went on a nice long commute home (about 50 miles for an 8 mile journey) and I have to say I'm amazed.
I imagine it's partly due to no longer being attached to undamped pogo sticks but the bike feels so different with these on. Handling is much livelier, and it feels like it wants you to fling it round corners rather than having to be wrestled round like the old ones.
Grip is much better as well, old nylon rear used to lock up as soon as you'd look at the brake pedal, this keeps spinning even slammed on with the clutch pulled in.
YBR 125>FZS600
Digitalize
PostPosted: 20:38 - 08 Jul 2010    Post subject: Reply with quote
I'm surprised they make Pilot Sportys for the thin tyres on a YBR! Standard equipment on them is something cheap and rubbish i think, friend just got a new one.
Pilot Sporty's are standard on Rieju RS2/Nkds and the YZF-R125, and i have to be honest, they are excellent tyres, my rear lasted nearly 9000km, and i just put a new one on for £60
Grip levels are excellent, only had them slip once at super low speeds on a slippy mini roundabout. Quick tap of the rear brake and it was fine.
I just don't feel confident enough to get knee down, but that might just be me, or my bike, it is quite tall.
1998 CB600F Hornet
herulach
PostPosted: 21:00 - 08 Jul 2010    Post subject: Reply with quote
Yep, its not a 50cc supermoto though, which is the reccomended application per the michelin site.
I kind of feel bad that mine were £75 the pair and £20 for fitting if you paid 60 for one!
YBR 125>FZS600
Digitalize
PostPosted: 21:11 - 08 Jul 2010    Post subject: Reply with quote
Mines not a supermoto either! Laughing
I took just my wheel and got them fitted for free, had to take wheel in and out myself, but let me clean the wheels properly.
Mines a 130 though, and i doubt the YBR's are even 100, not sure if that effects price. Also they had to order it in, as they don't carry small tires like these, so guess that made the cost higher.
I was happy with the price though, and thats all that matters Razz
1998 CB600F Hornet
The last post was made 15 years, 360 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 125.64 Kb
