Fuelling Bike While Balancing?
johnsmith222
PostPosted: 01:44 - 29 Jun 2010    Post subject: Fuelling Bike While Balancing? Reply with quote
Hi.
I was wondering if anyone can recommend me something reasonably cheap that I can connect to the bike to fuel it while balancing the carbs. The tank gets in the way and I'd rather use something that is pretty much the equivilent to one of those fuel filler cans with a hose on the end or something?
Can someone tell me what they're called so I can ebay one or link me to one.
Thanks for any help!
Alexio
PostPosted: 02:30 - 29 Jun 2010    Post subject: Reply with quote
You can use just about any small plastic container you can find with a bit of hose.
Flip
PostPosted: 02:42 - 29 Jun 2010    Post subject: Reply with quote
Coke bottle with bottom cut off?
Flip
PostPosted: 02:50 - 29 Jun 2010    Post subject: Reply with quote
If want something 'better' get a used fuel tank from a lawnmower or a generator? Thumbs Up
Was it one of these you were after?
https://cgi.ebay.co.uk/AUXILLARY-FUEL-TANK-PETROL-CAN-TANK-MOTORCYCLE-CAR-ATV-/110547250958?cmd=ViewItem&pt=LH_DefaultDomain_3&hash=item19bd212f0e
johnsmith222
PostPosted: 02:57 - 29 Jun 2010    Post subject: Reply with quote
Thanks guys for giving me your suggestions.
My friend who owns the Morgan Carbtune gave me the impression that I would need a special auxiliary fuel tank but it's probably just so he could borrow it also rather than doing more of a ghetto effort. I'll get something sorted.
Thanks for your help! Thumbs Up
yen_powell
PostPosted: 07:31 - 29 Jun 2010    Post subject: Reply with quote
Turn your own tank round and bungee it to the seat.
XT1200Z and a DR350 in bits
Grimnir
PostPosted: 07:47 - 29 Jun 2010    Post subject: Reply with quote
Works for me without the bungees - the tank cut-out for the airbox sits nicely on the rear seat
PostPosted: 11:54 - 29 Jun 2010    Post subject: Reply with quote
Longer piece of fuel pipe so you can put your real tank a convenient distance away is probably the easiest and safest.
Ichy
PostPosted: 13:17 - 29 Jun 2010    Post subject: Reply with quote
I use a bit of hose pipe and a funnel. Using a carbtune I can synchronise the carbs in less than a minute with just the fuel in the bowl, it doesn't take much as long as you have good access.
WetSparks
PostPosted: 23:34 - 29 Jun 2010    Post subject: Reply with quote
Please dont smoke whilst using the above method.
You might get some ash in your carbs Twisted Evil
Blue_SV650S
PostPosted: 23:46 - 29 Jun 2010    Post subject: Reply with quote
I'd be wary of this, some plastics turn to mush very rapidly when petrol is put in them, so you would end up with a melted container and petrol everywhere!! - not good!! Shocked
Does the tank on your bike not pivot back? if so you can just stick an appropriately placed block of wood to prop it up in situ ...
PostPosted: 00:02 - 30 Jun 2010    Post subject: Reply with quote
2 stroke oil tank (with the oil removed obviously).
Grimnir
PostPosted: 00:12 - 30 Jun 2010    Post subject: Reply with quote
Have you compared the particle size of fag ash to jet / needle holes?
Hang on - burning stuff near fuel vapour is bad? Shocked
WetSparks
PostPosted: 09:17 - 30 Jun 2010    Post subject: Reply with quote
Was that the penny I just heard drop Laughing
Ditto
PostPosted: 16:51 - 30 Jun 2010    Post subject: Reply with quote
I used an empty washing up liquid bottle and some plastic tube from my loobman.
The nozzle on the bottle is the perfect size to slip the hose over without any leakage.
https://comps.fotosearch.com/comp/FSD/FSD302/washing-up-liquid-bottle_~x12992361.jpg
And you will probably have to poke an air hole in the bottle to allow the fuel to flow.
CG 125 > Bandit 600 > CBR 600 FY > Street Triple R
The last post was made 16 years, 68 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 83.96 Kb
