braided hoses
Neepling
PostPosted: 23:27 - 28 Jun 2010    Post subject: braided hoses Reply with quote
Hi all,
Just picked up a ZX6R and although they work fine the front brake feels a little 'mushy' I was wondering if it is worth putting braided hoses on? How much difference do they actually make?
John
kt
PostPosted: 23:38 - 28 Jun 2010    Post subject: Reply with quote
They do help but dont always solve the problem, I would suggest you replace the brake fluid with new fluid before going down the hose route. Its easy and cheap to do but make sure you use the recommended fluid for your bike. brake fluid is an oil and only has a certain life which is always neglected. Brake fluid has a natural tendancy to absorb water and unless you know when it was last changed just assume that it has never been done. Its a job best done with the help of a friend and Do USE THE RECOMMENDED FLUID.
The Tot
PostPosted: 06:52 - 29 Jun 2010    Post subject: Reply with quote
Would also be worth taking the pads out and giving the pistons a clean with brake cleaner and a toothbrush and then give them a light smearing of silicon grease. Bleed the system through afterwards. You ought to notice a difference in lever stiffness and more responsive brakes after that.
Never argue with autism
Rowey
PostPosted: 08:48 - 29 Jun 2010    Post subject: Reply with quote
How old are the brake lines? Rubber ones eventually degrade till they become very flexible and will bulge under braking. Loosing some of the power and reducing feel.
What age is your ZX6R? If the pipes are more than a few years old, it wouldn't hurt to change them.
Otherwise just give them a good service. New fluid, new pads, clean the pistons, check the calliper seals, check the master cylinder seals and clean and check the discs.
ZX6R C6F.
PostPosted: 11:52 - 29 Jun 2010    Post subject: Reply with quote
Is it a ZX6R with the 6 piston calipers? If so strip and clean the calipers thoroughly (clean up the corrosion hiding behind the seals), then reassemble and bleed properly. If that doesn't work then braided hoses might help.
That said I have bike with 17 year old rubber hoses that are fine (RS125).
Kai.Wilson
PostPosted: 13:16 - 29 Jun 2010    Post subject: Reply with quote
What's the diffrance in ruber and metal hoses?
PostPosted: 13:23 - 29 Jun 2010    Post subject: Reply with quote
Rubber hoses have an inner rubber section, then some braiding (quite probably cloth braiding) and then a thick outer rubber coating. Metal ones have an inner pipe (probably something like nylon) with a braided covering (normally stainless steel).
The last post was made 16 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 2.37 - MySQL Queries: 13 - Page Size: 53.42 Kb
