Hornet Exhaust Studs (Now cleaned exhaust thread)
That_Hornet
PostPosted: 19:56 - 29 Jun 2010    Post subject: Hornet Exhaust Studs (Now cleaned exhaust thread) Reply with quote
Any help on getting them out. Got the plates off, just left with 4/6 studs in the engine.
They were properly rusted in.
Any tips on getting them out? Drill and Easy-outs? Or is it a case of taking it to Re-Bore to get them sorted?
https://i770.photobucket.com/albums/xx346/ThatHornet/b8d93588.jpg
https://i770.photobucket.com/albums/xx346/ThatHornet/9cba2f3a.jpg
Karma Thumbs Up
Jack
Edit:
Pic for Molly. Laughing
https://i770.photobucket.com/albums/xx346/ThatHornet/51a59ac0.jpg
DrDonnyBrago
PostPosted: 20:12 - 29 Jun 2010    Post subject: Reply with quote
If they are so rusted in they snapped off then an EZ out is the LAST thing you want to use - they will snap and you will cry.
Get some penetrating oil (not WD40) on the studs, then some heat and have at them with the mole grips... drilling them out is possible if you have a steady hand and some decent cobalt drill bits but if it were me and my attempts of brute force had failed I'd be taking it somewhere to get it sorted.
Good luck Thumbs Up .
kt
PostPosted: 20:18 - 29 Jun 2010    Post subject: Reply with quote
Op they look a mess, if you are really stuck and have enough space a last option would be to weld a piece of flat bar onto the studs than wont budge to act as a lever to remove them, Ive done this in the past and it has worked but only as a last resort. Good Luck
That_Hornet
PostPosted: 20:22 - 29 Jun 2010    Post subject: Reply with quote
I love this new banner for eBay at the bottom
Studs
So in your opinion its time to buy a plumbers torch and get at them with grips.
That_Hornet
PostPosted: 20:28 - 29 Jun 2010    Post subject: Reply with quote
Engine is completely out at the moment. Ready for a swap to my new bike. Mr. Green So room isnt the problem.
fiery tupp
PostPosted: 20:43 - 29 Jun 2010    Post subject: Reply with quote
Hi google this ( dreaded snapped studs ) plenty of tips & pics here for removing seized bolts . Smile
Digitalize
PostPosted: 21:03 - 29 Jun 2010    Post subject: Reply with quote
I got 4 stuck in mine too, took it to a guy i know, he welded a cross bar to them, heated them up and slowly worked them out.
Charged me £30 and worked a treat.
1998 CB600F Hornet
That_Hornet
PostPosted: 21:09 - 29 Jun 2010    Post subject: Reply with quote
So a welder could do it for me. Need to finds someone with some welding gear. Thumbs Up
Digitalize
PostPosted: 21:16 - 29 Jun 2010    Post subject: Reply with quote
He wasn't really a welder, he was an engineer who does a lot of bike stuff as a hobby.
Guess a welder could probably do it for you though.
1998 CB600F Hornet
That_Hornet
PostPosted: 21:18 - 29 Jun 2010    Post subject: Reply with quote
Would do it myself but not got one yet. Laughing
Still adding to my collection of tools, next on the list is a compressor Thumbs Up
But ill have a ring around tomorrow.
m0l0t0v
PostPosted: 22:28 - 29 Jun 2010    Post subject: Reply with quote
Those downpipes look disgusting Shocked
Re-using them?
What are you actually doing with the bike/engine?
That_Hornet
PostPosted: 22:37 - 29 Jun 2010    Post subject: Reply with quote
Woop Woop, Stud extractors to the rescue!
All out, used the 8mm stud extractor and it rounded it off, then tried the 6mm and because i rounded it it fitted on just! Then undone it, very slowly making sure not to fuck it up.
Really happy now! Very Happy
https://i770.photobucket.com/albums/xx346/ThatHornet/a7f18034.jpg
That_Hornet
PostPosted: 22:42 - 29 Jun 2010    Post subject: Reply with quote
Re-using them?
Laughing Downpipes i will be trying to clean up tomorrow then refitting. Any tips, not many monies atm.
As for the engine. As you know i have f*cked my frame. So i purchased another Hooner from Liverpoooool, for the grand sum of £650.
Its scruffy, leaky rad and the gearbox output shaft is rounded, due to a dick who fitted the sprocket with the washer on the wrong side. Rolling Eyes
But am replacing engine with mine and finally getting a running bike. (as long as it goes well. Wink )
Digitalize
PostPosted: 22:46 - 29 Jun 2010    Post subject: Reply with quote
In all honesty, the downpipes look fucked, the plates are rusted quite bad (not as bad as mine were....) and i doubt you'll get a proper seal with them. Can get replacement new shiny ones or £200ish, or pick up some more second hand ones and clean them up.
Or soldier on with those.
1998 CB600F Hornet
kt
PostPosted: 22:48 - 29 Jun 2010    Post subject: Reply with quote
If the downpipes are stainless steel then get some brick acid from a builders supplier and mix it 50/50 with water and brush onto the pipes (wear gloves and eye protection), hose of with clean water 2 minutes later , repeat if necessary and use some scotchbrite or fine wire wool for the stubborn stuff. They should come up as almost new.
m0l0t0v
PostPosted: 22:50 - 29 Jun 2010    Post subject: Reply with quote
Wirewool, autosol and loads of elbow grease!
You can get a polishing kit for 20 quid form egay taht will do the job in a much much shorter time (and achieve better results than wirewool)
I'll try and get some pictrues of the old and new downpipes (Hornet's) tomorrow and show you the difference Laughing
That_Hornet
PostPosted: 22:51 - 29 Jun 2010    Post subject: Reply with quote
supermono wrote:
brick acid
Brick acid you say. Thinking
Think i might try that.
I have another set of pipes coming with the new bike on Friday, so should they be in better nick i will use them.
That_Hornet
PostPosted: 22:52 - 29 Jun 2010    Post subject: Reply with quote
Any links to the polishing kit molly?
Im lazy. Laughing
m0l0t0v
They're not stainless. You can buy stainless steel oens but the original ones weren't.
What you can do is buy a big tub to be able to fit them in and buy lots and lots of malt vinegar from sainbury's/tesco's and then soak the downpipes in it. Then leave them in there for a night or two. You'll be surprised how easy all the crap comes off! Shocked
Though your bike will smell like a chippy for a few miles Laughing
m0l0t0v
PostPosted: 22:55 - 29 Jun 2010    Post subject: Reply with quote
https://shop.ebay.co.uk/perfectpolishingkits/m.html?_nkw=&_armrs=1&_from=&_ipg=&_trksid=p3686
That's the guy I bought mine from. Changed slightly but you get the idea.
You get 3 abrasive mops, 3 polishing mops and 3 polishing bars. With some lime powder (no idea what for!) and a mask so you can feel like your killing pigs... or something. Shifty
kt
PostPosted: 22:56 - 29 Jun 2010    Post subject: Reply with quote
Yes brick acid is the ticket provided it is diluted although I have used it neat for stubborn areas on stainless pipes, it is also widely used to clean road crude from alloy car wheels. Its as cheap as chips and has other uses for cleaning stubborn dirt of smooth surfaces but DO NOT use it on mild steel exhaust pipes.
That_Hornet
PostPosted: 22:58 - 29 Jun 2010    Post subject: Reply with quote
Ok Thumbs Up Wink
Digitalize
Fairly sure they are...?
1998 CB600F Hornet
kt
PostPosted: 23:00 - 29 Jun 2010    Post subject: Reply with quote
I could have swore they were stainless as well?
m0l0t0v
PostPosted: 23:01 - 29 Jun 2010    Post subject: Reply with quote
I might be wrong... I think they're not but you can buy some so they don't go all crap as Hornet headers do. If they were stainless then they wouldn't corrode so easily... surely?
The last post was made 16 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 135.05 Kb
