Torque Wrench
rac3r
PostPosted: 11:05 - 30 Jun 2010    Post subject: Torque Wrench Reply with quote
Recommend me a decent one which doesn't cost £££££££ please!
This is the one I've found so far:
https://www.amazon.co.uk/dp/B0001K9T2O/ref=asc_df_B0001K9T2O699184?smid=A3P5ROKL5A1OLE&tag=googlecouk06-21&linkCode=asn&creative=7974&creativeASIN=B0001K9T2O
Chequered Flag
Aka Matt
PostPosted: 12:37 - 30 Jun 2010    Post subject: Reply with quote
I've got that along with the 1/2" square drive they do too. For the price, they are a good bit of kit (think I paid £40 for my one a year or so ago).
Current bike(s): 2016 Tuono 1100 Factory, 1998 Hornet 600
Previous: 1998 YZF600R Thundercat, 2001 Bandit 600, 2002 GSX-R 600 K2, 2011 Tuono R, 2013 Z1000SX
Serendipity
PostPosted: 13:01 - 30 Jun 2010    Post subject: Reply with quote
I’ve had that Draper one for several years as my “small” torque wrench. I only ever used it for stuff needing very low torque. I have a full size torque wrench for the bigger stuff. The draper only goes to 80Nm or about 59 ft.lbs. so no good for wheel spindles etc..
The Draper one is a decent enough tool, well made and has served me well, but I always found the scale did my head in. The wrench is set in inch pounds while most of my workshop manuals are in foot pounds. This tends to strain my already weak mental arithmetic past breaking point. Embarassed If you can see past this (or work in Newton Metres) you’ll love it.
A while ago I also bought the smallest torque wrench in Halfords Professional range. Rather expensive, but I much prefer it to the Draper. That fails to fit your £££££ criteria though. Smile
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
The Tot
PostPosted: 13:04 - 30 Jun 2010    Post subject: Reply with quote
+1 for the draper 3/8". Used it for engine mounting bolts, brake caliper mounting bolts and caliper bolts without much hassle. I used the Nm scale anyway so it does the job.
Never argue with autism
dodgydog
PostPosted: 13:14 - 30 Jun 2010    Post subject: Reply with quote
I used the draper one for ages at home, until some fools bought us all snap on kit for work, when I left the place it had to be handed in. bit of iron bar in the box was about the same weight, luckily they didn't open box and check it Very Happy Very Happy Very Happy
£200 of kit up there.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
rac3r
PostPosted: 13:15 - 30 Jun 2010    Post subject: Reply with quote
I just need it for the brake calliper mounting bolts
Chequered Flag
DrDonnyBrago
PostPosted: 13:31 - 30 Jun 2010    Post subject: Reply with quote
I have a clarke 3/8" torque wrench that I bought from MachineMart, looks identical TBH...
Isn't bad, found the scale to be a bit wierd as mentioned previously but it just means I use the MKg scale and divide all the Nm values by 10 Thumbs Up .
(well 9.81 if you want to be a pedant)
Quote Me Happy
Now at the risk of being flamed here - just go by feel. If you have a torque wrench, brilliant, use it. If not just do they up tight, not as tight as you can possibly go, but until they're done up then nip them slightly.
I usually use a bit of threadlock on those as well.
beast rider
I've got a 1/2 inch one from argos, it rarely gets used as it only goes down to 28nm and anything under that is hand tight for me anyway.
willis1337
PostPosted: 13:47 - 30 Jun 2010    Post subject: Reply with quote
https://www.amazon.co.uk/Draper-30357-Micrometer-Adjustment-Torque/dp/B0001K9S52/ref=pd_sim_diy_2
This one seems okay for rear wheel also etc and only 52p more.
SamJL
Halfords professional range is really good, and you get a lifetime guarantee! Might be a bit over budget at around £60, but there tools are great!
https://www.halfords.com/webapp/wcs/stores/servlet/SearchCmd?srch=tourque&x=0&y=0&action=search&storeId=10001&catalogId=10151&langId=-1
2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX Very Happy
johnsmith222
PostPosted: 14:02 - 30 Jun 2010    Post subject: Reply with quote
willis1337 wrote:
I find the range too high to do the sump bolt and other bolts.
My recommendation is that you buy both torque wrenches.
Mark65
PostPosted: 16:48 - 30 Jun 2010    Post subject: Reply with quote
+1 for the halfords pro one, i think they are made by norbar.
Mark
Shay HTFC
PostPosted: 16:52 - 30 Jun 2010    Post subject: Reply with quote
Just tighten up your brake calliper mounting bolts so they are tight, but not stupidly tight and ride to the nearest garage and ask them just to do them up using their torque wrench.
Unless you actually want the kit there is no point spending loads of wonga for a one off job.
Full Motorbike License - GS500E '95
metalangel
PostPosted: 19:51 - 30 Jun 2010    Post subject: Reply with quote
+2 to the Halfords one, it is the most solid and well-built tool I've got. Not to mention it looks like it would stove a chav's head in with one swing.
That_Hornet
PostPosted: 19:56 - 30 Jun 2010    Post subject: Reply with quote
3+ for Halfords, have 2 for some reason, think my dad gave me one.
Give me a pm if you want one, might sort something out..........
smegballs
PostPosted: 19:58 - 30 Jun 2010    Post subject: Reply with quote
I'd go with Joe on this one.
I'm under the impression that unless your torque wrench is a good good one then you might as well go by feel.
With a bit of practice its apparently possible to learn to feel the amount of torque you need. Useful too is stripping off bolts in wrecked crancases and such to get a feel for how much torque can be applied before things go ping.
PostPosted: 20:03 - 30 Jun 2010    Post subject: Reply with quote
I've got the Draper. Bought it for re-fitting the forks on my TZR. Comes in handy all the time.
Dazbo666
PostPosted: 20:09 - 30 Jun 2010    Post subject: Reply with quote
I have a Clarke branded torque wrench from Machine Mart. Only used it half a dozen times, but it's been really good quality even at £20
https://www.machinemart.co.uk/shop/product/details/cht141-1-2in-drive-torque-wrench
Word of the day : DILLIGAF
rac3r
PostPosted: 23:31 - 30 Jun 2010    Post subject: Reply with quote
I'm just going to tighten it normally Thumbs Up
Chequered Flag
Raffles
PostPosted: 23:50 - 30 Jun 2010    Post subject: Reply with quote
I'm with Joe and Smegballs on this one.
Torque wrenches are for people with too much spare cash.
neil.
PostPosted: 23:54 - 30 Jun 2010    Post subject: Reply with quote
+4 for the Halfords'. It's one of my most reached-for tools. The manafactures specified particular torques all over the bike for a reason so I'd like to adhere to that.
Quote Me Happy
PostPosted: 06:40 - 01 Jul 2010    Post subject: Reply with quote
I would just lie to add to my previous comment about going by feel - I also have a Halfords Pro torque wrench - a great bit of kit. While having a torque wrench for these kinds of jobs is not essential, it is nice to know everything has been put back together just right. I say splash some cash on a decent wrench, 6 months down the line you'll not notice the money gone but will be using the wrench a lot. If you don't plan on doing much maintenance yourself then just go by feel this time.
PostPosted: 06:53 - 01 Jul 2010    Post subject: Reply with quote
Just do them up tight with a normal spanner or 3/8 ratchet.
beast rider
PostPosted: 07:39 - 01 Jul 2010    Post subject: Reply with quote
After posting on this page yesterday i went to use my torque wrench to do up the head bolts on my bandit and the damn wrench is broke!
Looks like i need a new one aswell .
The last post was made 16 years, 67 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.27 - MySQL Queries: 13 - Page Size: 125.33 Kb
