de restriicting moped
kurtishill93
PostPosted: 18:49 - 02 Jul 2010    Post subject: de restriicting moped Reply with quote
hi i have a keeway flash can you pleaasseeeee tell me how to de restrict it i really dont no what to do....... it is a 50cc 2 stroke.
many thanks
xxx
the bike currently is doin 34 mph but i am not sure if anything has beenn done to it.... so any1 can you tell me every little thing i can do to this bike just by tweeking with it
thank you so much
xxxx
khill
Rob W
PostPosted: 18:50 - 02 Jul 2010    Post subject: Reply with quote
Welcome to BCF.
NewbRider15
PostPosted: 18:54 - 02 Jul 2010    Post subject: Reply with quote
Not the most helpful post but you could take it to any motorcyle/moped dealer and they'll derestrict it for a very small price. Usually its a washer in the carburetor or a throttle restrictor (doesnt let you pull the throttle all the way). Hope this helped somewhat.
Now on - 1986 Kawasaki ZL400 Eliminator (33bhp restricted)
Own - 2009 Huatian HT50QT-25 Scooter
Hazylogic
PostPosted: 21:02 - 02 Jul 2010    Post subject: Reply with quote
Now it is important that you pay attention, that is, if you wish to have a faster bike:
You need to get yourself one stick of kitkat and break it up into five equal pieces.
Three go in the tank.
The other two go up your nose.
Yes, it may sound silly, but trust me, the choclate and wafer combined will act like a turbo in your engine.
The two up your nose will also aid in helping you react quicker Thumbs Up
Remember, only one stick of kitkat!
Word of advice: save up the foil after each kit kat and you can use it to get a nice chrome effect on your zorst.
stuartadair
PostPosted: 22:30 - 02 Jul 2010    Post subject: Reply with quote
1. Take the cover off the drive belt.
2. Take the 17mm nut off the variator. You might need an air wrench though as it usually is tight and needs to be shocked off
3. Remove the spacer that prevents the variator moving fully out.
4. Check if you have a pink wire coming from the rear gear pulley to the CDI. If you do, disconnect it.
Enjoy Very Happy
ajbsmirnoff
PostPosted: 22:38 - 02 Jul 2010    Post subject: Reply with quote
Stripes. Stripes, if positioned correctly will make any vehicle go faster.
As will a slightly (or grossly) larger exhaust exit. Though that may just be for the Vauxhall Corsa.
Redoko
PostPosted: 23:52 - 02 Jul 2010    Post subject: Reply with quote
Pass your test and buy a bigger bike.
hmmmnz
PostPosted: 02:51 - 03 Jul 2010    Post subject: Reply with quote
wow,
you guys, gee whiz, im sure you all were learner riders at some point,
i think i would have been pretty fucked off by the answers given so far
(excluding stuartadair's)
the asker, used reasonably good english, reasonable grammar,
and didn't sound like a little chav,
any way kurtishill93
pretty much as stuart has said,
with the addition of rollers,
if you have trouble getting the 17mm nut off the variator,
i use a standard "hamonic balancer remover"
https://i73.photobucket.com/albums/i237/Big-F00T/MISC/pulley_stock_puller.jpg
on the fan side of the crank
(unbolt the fan cover, remove the fan, and loosly bolt the remover to the bolts that the fan used, the long side of the puller will jam and allow you to unbolt the nut on the other side)
once you have remover the washer in the valiator
https://www.scootnfast.com/images/derestrict04.jpg
then i would change the rollers to 7 gram ones,
in my experience, thats a nice balance between top speed and acceleration,
the next thing is exhaust and cdi
you can get both from here along with loads of other tuning parts, and engine spares
good luck
the humans are dead
I kick arse for the lord
The last post was made 16 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 61.79 Kb
