PEUGEOT 100cc hole in piston
blaze187
PostPosted: 18:43 - 05 Jul 2010    Post subject: PEUGEOT 100cc hole in piston Reply with quote
hiya everyone
im rebuilding a 100cc peugeot 2 stroke at the min and its blown a hole in the top of the piston dus anyone no y this may of happend someone told me it could be a cdi problem could this be true
radical
PostPosted: 18:57 - 05 Jul 2010    Post subject: Reply with quote
Possibly running too weak (petrol/air mix) and/or incorrect plug, is the exhaust system standard or aftermarket?
MaybeGuy
PostPosted: 19:11 - 05 Jul 2010    Post subject: Reply with quote
new exhaust without being jetted for it.
blaze187
PostPosted: 19:12 - 05 Jul 2010    Post subject: Reply with quote
its all standard . thanks il have to have a look at that
radical
PostPosted: 19:33 - 05 Jul 2010    Post subject: Reply with quote
Op check that the air filter is intact as if it is missing or the air box has been modified without rejetting the carb this would also make the bike run weak and cause the holed piston.
stevo as b4
PostPosted: 22:35 - 05 Jul 2010    Post subject: Reply with quote
It's quite unusual on a std one for that to happen. maybe there was an air leak somewhere that let it run too weak? These type of faults can be hard to find, if it's not the filter-carb-inlet manifold causing the problem.
On my SF100, i melted the sides of the piston, about 40miles after having fitted a modified head that increased the compression ratio. i still don't know to this day exactly what i did that cured the problem with the new top end i fitted, as i used a 1grade cooler plug, went up one size on the main jet, and used 98RON fuel often with a drop of octane booster for good measure.
blaze187
PostPosted: 22:36 - 05 Jul 2010    Post subject: Reply with quote
thanks for all your help just got abit worried when got told it was the cdi il give it all a good look over now .
blaze187
PostPosted: 22:03 - 07 Jul 2010    Post subject: Reply with quote
iv had a look at it now and found 2 screws missing from the bottom of the air box and the air filter pushed to one side do you think this could of been the prob
radical
PostPosted: 22:23 - 07 Jul 2010    Post subject: Reply with quote
It could well have caused the problem as the increased flow of air would have weakened the mixture which would cause a holed piston if the main jet in the carb had not been increased in size to compensate for the missing filter.
The last post was made 15 years, 356 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 6.29 - MySQL Queries: 13 - Page Size: 57.15 Kb
