R125 starting issue
wheelie916
PostPosted: 20:35 - 20 Jun 2010    Post subject: R125 starting issue Reply with quote
Hey guy's
Ive just rebuilt my r125 with a new top end and when i tried the first time she started first time on the button and run sweet as a nut.
Since then i cannot get her to start unless i temp block the air pipe then she starts and runs... again as sweet as a nut and will start ok if i swtich of and on again, its only when she is left a while she wont start and I have to block the air pipe and she will start fine.
I have changed the plug, the timing is spot on(checked every time)
The only thing is the fuel its been in the tank for about 3 months.
Does anyone have an idea as to why she wont start unless i block the air pipe.......
Many thanks for any help.
Jas
wheelie916
PostPosted: 20:58 - 05 Jul 2010    Post subject: Reply with quote
anyone help with this problem?
radical
PostPosted: 21:01 - 05 Jul 2010    Post subject: Reply with quote
Does the fuel smell stale? if so just empty and replace with fresh petrol
TUG
PostPosted: 21:05 - 05 Jul 2010    Post subject: Reply with quote
you've done something wrong when rebuilding it, if your rebuilt it yourself then more than likely you've plumbed things in wrong.
We've done a few of these, let me guess, aftermarket exhaust? didnt change the oil ever 1600 miles?
Haz ER-5, innit!
wheelie916
PostPosted: 17:04 - 06 Jul 2010    Post subject: Reply with quote
the bikes completly std rebuilt as cam tensoner failed causing bent valves so i replaced the top with a new one and rings, gaskets.
the fuel tank was stored in shed with the lid off for a while would the petrol go bad then?
how do i tell bad fuel?
everything is back as per workshop manual, all the timing is spot on
I cant understand why she starts if i block the air inlet for a short while but wont start without..... she fires up without the need to block air inlet when warm no problems.
when she starts she runs brilliantly with no probs......
Thanks for the help guy's
Jas
The last post was made 16 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 42.6 Kb
