Bike pisses coolant... the hose keeps slipping off
Jayy
Mr. Ponzi
PostPosted: 22:43 - 06 Jul 2010    Post subject: Bike pisses coolant... the hose keeps slipping off Reply with quote
Had the bike a month now and no problems up until Friday or Saturday night. Went out for a hoon, parked up at Tesco, nipped in and got some cigs and came straight back out. Must of been 5 minutes tops. Then my phone rang and I was talking to my mate and next minute, SPLASHHHHH.
I didn't realise what had happened at first, was looking around to see if some water had come off the roof, then I saw coolant dripping out of the hose that connects to the engine. It literally dumped all over it on the floor in 2 seconds.
I managed to get it back home by riding it in short bursts (was only 3 miles) and letting it cool down for 10 mins at a time.
Bought some coolant from the petrol station and TUG filled it back up and moved the jubilee clip back into position from were it had managed to move about 2cm. I put it down to the insane vibrations from the bike because they just shake violently when you're riding them (it even moves on it's own when it's got the choke on it's vibrating that much).
So, I've put about 100 miles on it since then from riding about. After being out on it today, I got back to my garage and turned it off.
Few hours later, about 9.30pm tonight, went in to go the shop on it. Wheeled it out the garage and started it up, went to go back in to get my lid and saw a trail of fluid on the floor, went back out and the hose had come off again. TUG doubled checked it and tightened it up when he came down on Saturday so not sure why it's come off again.
Do you think this is something more sinister than just vibrating itself off? TUG reckons it could be something to do with the cooling system not working properly and building up pressure and just forcing it off?
Picture below:-
https://i48.tinypic.com/aaf72t.jpg
2wheelsteve
PostPosted: 22:48 - 06 Jul 2010    Post subject: Reply with quote
better jubilee clip me thinks and make sure its all dry when you put it together, good luck
hornetmike
PostPosted: 22:50 - 06 Jul 2010    Post subject: Reply with quote
sounds like stuck thermostat, take it out and test it in boiling water.
87 Honda CG 125 - 97 ER5 - SR 50 -81 Z250- 96 CBR 600 F- 94 GPX600R 88- GPX 400R- 87 GS 125 - 2006 Honda CB600F- 2003 ER5 - Honda CBF 1000 2009 - Honda CBR 600 RR 2011
Current BMW R1200GS 2010
Jayy
Mr. Ponzi
I said that (being the mix master mechanical genius that I'am) just thought the clip was fucked, going to get a new clip tomorrow and try it out, if it does it again, I will get the dealer to pick it up as it's under 3 month warranty.
Jayy
Mr. Ponzi
PostPosted: 22:51 - 06 Jul 2010    Post subject: Reply with quote
Would a stuck thermostat cause this effect?
2wheelsteve
PostPosted: 23:04 - 06 Jul 2010    Post subject: Reply with quote
It would because water expands and something has to blow but try the clip first, its cheaper Smile
Jayy
Mr. Ponzi
PostPosted: 00:11 - 07 Jul 2010    Post subject: Reply with quote
I'm scared it is something more serious and riding it will cause more damage to it now! If I get a new clip and make sure it's solid, it might blow something else up if it can't get out there.
SamJL
PostPosted: 00:34 - 07 Jul 2010    Post subject: Reply with quote
Are the water pipes rock hard before the clip comes off? Put the pipe back on, let the bike heat up, and just see if the water pipe's are getting bulges and going hard.
It sounds like your water system has far to much pressure in it, could be a number of things, from a thermostat to a head gasket. It could even be something as simple as needing a new radiator cap. I doub't its a head gasket, Im not even sure you would get those symtoms? An MOT centre can check if a head gasket is gone by putting an emissions tester in to the coolant system and checking if there is any exhaust gasses being emitted. I would imagine they would do this for free, although its very unlikely to be the head gasket.
Try a new clip, if the pipes start bulging and go hard, replace the radiator cap, if that doesn't fix it, try the thermostat. I think the radiator cap is the most likely fix!
2009 CBR1000RR
2004 KTM 200SX
2004 KTM 65SX Very Happy
st3v3
PostPosted: 00:55 - 07 Jul 2010    Post subject: Reply with quote
Is it not better to replace the clip and have something more serious blow up now, while it's under warranty? Wink
The last post was made 16 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 60.36 Kb
