| el_oso |
 el_oso World Chat Champion
| radical |
 radical Spanner Monkey
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 18:12 - 05 Jul 2010 Post subject: |
CV Carbs.
May not be the slides sticking in the body, could be the diagphrams.
Curiouse that they have all gone at teh same time... you'd expect one to start fluttering, then you'ge get progressively worse running, then you'd have a look and find one or two obviousely 'gone' and maybe one pin-holed.
Worth looking at the plumbing... if effecting all four, and asking if you have taken them off to clean or have tried DIY balencing or something.
Bike CV's often not 'damped' like an old car type dash-pot SU CV carb, the diagphram is worked both ways, vacuum above balenced by vacuum below, from pitot tubes either side of the main choke.
some-times externally plumbed. in which case look for perished pipes ariound the carb, or internally.... clogged or firred jets.
Could also be fir in the carb-body, that a spray of carb cleaner wont shift, unless you strip them....
Which is probably the answer.... full carb-strip.
or Doh! Moment... you HAVE stripped them!
Were they that bad before you did?
Did you put them back together properly?
Did you use RTV to get stuff to seal (or not!)
Did you use new gaskets & diagphrams? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| el_oso |
| Kickstart |
 Kickstart The Oracle
 Posted: 20:26 - 05 Jul 2010 Post subject: |
On CV carbs the slides are there for the mixture, not the throttle. Hold them all wide open and other than screwing up the mixture it probably shouldn't significantly increase the idle speed.
They might be sticking, but you probably have another issue with the carbs.
If the throttle cables are too tight then it can cause the throttle to stick. Air leaks after the carbs (or on the throttle spindles) can increase the idle speed as well.
| Phoenix |
 Phoenix Twisted Firestarter
| Phoenix |
| el_oso |
| Kickstart |
| el_oso |
| Kickstart |
| el_oso |
| Phoenix |
| el_oso |
| Kickstart |
 Posted: 11:31 - 07 Jul 2010 Post subject: |
With the FZ the only thing I could think was that the carb slides were made from a material that had reacted with something over time. They appeared to be some kind of nylon like plastic.
See how much new slides are on their own. If not all of the slides are sticking then swap them round and see if the one that sticks moves with the slide of stays with the carb body (remember that the needles might be different between cylinders).
The last post was made 16 years, 92 days ago. Instead of replying here, would creating a new thread be more useful? |
