No power! ?
X9-rider
PostPosted: 17:24 - 07 Jul 2010    Post subject: No power! ? Reply with quote
Hello.
MY CG battery started dieing and lights getting dimmer. then stopped working and the fuse 10amp next to the battery blew.
For last few days been riding round with no power, with the LED Brake light the CG running with no battery the Generator could power the brakes lights only, but struggles with indicators.
Anyway i have charged and fitted a brand new 10amp fuse and new battery, But nothing works.
Check the CG with volt meter, its supplying 14-15 volts to the battery, then checked the battery and its at 13.5vs. so the power is there but he bike is not getting it.
Any ideas ? at the mo for last week i have had to use indicators with bike revving hard to get them to flash or work. or use hand signals, and cant go out when dark Sad
Anything?
SW Motech Shop UK
PostPosted: 20:24 - 07 Jul 2010    Post subject: Reply with quote
Check all the block connectors on the wiring loom are clean of corrosion and clean any earthing points you can find. Worth a try
https://www.motorcycle-road-and-race.co.uk and https://www.sw-motech-shop.co.uk/ and https://www.motorcycle-luggage.co.uk/
X9-rider
PostPosted: 20:55 - 07 Jul 2010    Post subject: Reply with quote
will try it, my plan was tomorrow after going to cinema to see the new film predators, would come home strip the loom out and give good clean.
If its not that , what else could make the Cg power-less ?
Drongo
PostPosted: 00:06 - 08 Jul 2010    Post subject: Reply with quote
My mate had a similar problem with his CG, pish lights, indy's not flashing, it was a bad connection on the positive wire from the battery, the bullet connector. Just gave it a squish to make it tight again and all was good.
Might be worth checking.
HTH.
X9-rider
PostPosted: 10:32 - 08 Jul 2010    Post subject: Reply with quote
ill mark what wire goes where when i do the loom,
X9-rider
PostPosted: 19:51 - 08 Jul 2010    Post subject: Reply with quote
What els cant cause the bike to not have power ? i check the light output and is only receiving 0.86vs
X9-rider
PostPosted: 13:17 - 09 Jul 2010    Post subject: Reply with quote
BIke Stripped today, and all now working Smile
https://farm5.static.flickr.com/4117/4777176892_ed4ac5ce21.jpg
X9-rider
PostPosted: 11:54 - 13 Jul 2010    Post subject: Reply with quote
back to square 1. Fitted a new regulator today, didn't solve the problem.
X9-rider
PostPosted: 19:47 - 13 Jul 2010    Post subject: Reply with quote
I cant go out at night because the lights just flicker and the indicators are AWOL.
Bike off, CG Battery reads 13.30v
Bike ruining, CG battery reads 14.60v
CG Wires from loom plugged into volt meter rather then Battery, Idle speed no revs : 8.56v
tested the side light ( 1 side light bulb 5w ) reading at idle is : 0.74v revved Reads: 1.60v How i did it ( so you know if i did it correctly ) 2 wires on the side light bulb + an - connected + to the + on the volt meter and - to the - on the volt meter.
If i could find the loom brake i could solve it. but could be something els or is that the be the only thing left ? is the loom
ThoughtContro...
PostPosted: 20:37 - 13 Jul 2010    Post subject: Reply with quote
So your battery is fully charged, no problems there
Your alternator and rectifier look to be working OK
Which should read 12V and something above that. This means that you've most likely a high resistance (read Crap/Corroded) connection somewhere in the lighting circuit that's dropping most of the voltage. Could be a connector/wire, wire/wire, earthing point/wire.
Like the man said above check the connections where possible. Clean em, crimp em, etc. A wiring diagram might help you more easily trace what wire does what, than trying to trace back.
Prize cunt
Ichy
PostPosted: 20:45 - 13 Jul 2010    Post subject: Reply with quote
Does the horn work?
Attach a wire to the negative side of the battery, connect it to any bare metal part of the frame, anything?
Connect the same negative wire to the negative side of the headlight, anything?
Ichy
PostPosted: 20:50 - 13 Jul 2010    Post subject: Reply with quote
Are you sure the fuse is still good?
X9-rider
PostPosted: 21:50 - 13 Jul 2010    Post subject: Reply with quote
Horn works perfectly, nice loud, even when bike not running, and fuse is fine. If stops raining ill recheck all connectors again. i have wiring diagram.
Noxious89123
PostPosted: 22:17 - 13 Jul 2010    Post subject: Reply with quote
Could be a broken wire causing a poor connection?
X9-rider
PostPosted: 11:06 - 15 Jul 2010    Post subject: Reply with quote
trying for the 3rd time today
The last post was made 15 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 8.01 - MySQL Queries: 13 - Page Size: 98.96 Kb
