| Olids07 |
 Olids07 Two Stroke Sniffer
| Glenben92 |
 Glenben92 Nearly there...
 Posted: 19:32 - 08 Jul 2010 Post subject: |
as for the differences.. usability of power with a 4stroke will improve massively to waht you're used to. alot less changing gear for you my friend oh and more smoothness compared to a single cylinder  ____________________ 57 Huoniao HN125-8 - , 97 Kawasaki GPZ500S -
99 Yamaha FZS 600 -
Mod 2 Passed - 01/10/2010 |
| imanupstart |
 imanupstart Traffic Copper
 Posted: 19:36 - 08 Jul 2010 Post subject: |
Great choice mate. Upgraded my bandit to a cbr600f and I'm loving it to pieces. Not as focused as the other sports 600's and like you said, comfortable, but it sure has some go in it  |
| Alexio |
 Alexio World Chat Champion
| Frost |
 Frost World Chat Champion
 Posted: 19:38 - 08 Jul 2010 Post subject: |
Throttle response with regards to revs will be about the same. With regards to road speed it is obviously much higher. Gears are also spaced out a lot more. Expect torque to be much higher so you can actually use low revs without it feeling like it's about the stall. On that note remember that you can set off perfectly well at 1.5k rpm, don't do what i did and rev it to 5k and slip the clutch forever as first gear is longer You will also not need to keep it int he power band so much to make good progress, for a while it will feel like any speed in any gear will do.
Direction change will require more counter steering as its heavier and has fatter tires. Taking pillions is a shit load easier. Brakes are as powerful as your current bike, but building up speed is loads easier, so the brakes may feel not so great as stopping distances will appear to have increased with regards to acceleration distances.
Basically just don't go thrashing the nuts off it for a bit, get used to the brakes, weight handling and grip levels before you start doing 120mph  |
| el_oso |
 el_oso World Chat Champion
| Olids07 |
| Olids07 |
| Olids07 |
| Olids07 |
 Posted: 01:07 - 09 Jul 2010 Post subject: |
That's good to hear, I'm glad that you mentioned not to rev it to 5k as the Aprilia loves the high revs for pulling away in first gear! I think that will be one of the hardest things to adapt to, realising that I don't have to slip the clutch and keep the revs high at low speeds then as I've gotten so used to it after the past 3 years.
With regards to direction change and weight; will the difference in weight be very noticable in both low speeds and high speeds? I believe the difference in kg between the RS and CBRf is 60kg. I'm looking forward to having the better pillion performance, I weigh 13 stone and having someone on the back of the RS is hell!
Haha I planned to take it out early every morning and have a ride down the local backroads to get used to pulling away, gear changing and braking etc. Although I can't wait to give it a spin down the local A roads after I've gotten used to it!
Thanks for all the advice
| DaFrostyOne wrote: | Throttle response with regards to revs will be about the same. With regards to road speed it is obviously much higher. Gears are also spaced out a lot more. Expect torque to be much higher so you can actually use low revs without it feeling like it's about the stall. On that note remember that you can set off perfectly well at 1.5k rpm, don't do what i did and rev it to 5k and slip the clutch forever as first gear is longer  You will also not need to keep it int he power band so much to make good progress, for a while it will feel like any speed in any gear will do.
| imanupstart |
| Alexio |
| Olids07 |
 Posted: 20:27 - 09 Jul 2010 Post subject: |
Sounds like a good shout, after 3 years with the Aprilia's clocks I couldn't stand having analogue clocks!
I have an 01 myself, I would say 01 and on would be your best bet, digital clocks and fuel injection [/quote] |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 22:58 - 09 Jul 2010 Post subject: |
go for a daytona 600 . bit different and are lovely bikes. a firend of mine picked and 04 model with 10000 miles on the clock for £2500. well worth looking at! |
| Frost |
| Olids07 |
 Posted: 01:04 - 10 Jul 2010 Post subject: |
I would describe myself as a "sensible" town rider, with experience on A roads. One of the main reasons for me to get a 600 was the fact that I'll be doing a lot of motorway riding soon, and the RS (or any other 125 I presume) simply can't handle the cruising speeds (mine especially likes to vibrate!) and cross winds on a motorway. I keep going over the pros and cons of upgrading, but all the reasons you're giving me would be immensely helpful to me (especially the crosswind stability), so thank you for reinforcing my pro list!
Ah I had the same with the RS, I did my CBT and test on one of those old reliable yamahas, and the clutch was so much easier to control and pulling away with low revs was easier, completely unlike the RS, so I've kinda had the experience before of buggering up pulling away!
| DaFrostyOne wrote: | | Olids07 wrote: | With regards to direction change and weight; will the difference in weight be very noticable in both low speeds and high speeds? I believe the difference in kg between the RS and CBRf is 60kg. I'm looking forward to having the better pillion performance, I weigh 13 stone and having someone on the back of the RS is hell! |
It depends on how your riding. If your riding it like it's a grand prix bike then the extra weight is going to be very noticeable. If your riding it like a commuter bike, not very noticeable.
The bike will feel more planted and stable, less vulnerable to cross winds, more sure footed and having a pillion will still be noticeable, but it will feel more like having a child on the back.
Pulling away will be the first thing you fuck up, but it's not going to be dangerous just needlessly revvy for a bit, but you'll get used to it. |
| Olids07 |
The last post was made 16 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
