CG125 Oil: Recommendations/Opinions?
Ingah
PostPosted: 01:41 - 03 Jul 2010    Post subject: CG125 Oil: Recommendations/Opinions? Reply with quote
I just wanted some opinions on whether / what it is "worth" to run a 2002 CG125 on "better" engine oil.
According to this guy: https://hondacg125.awardspace.com/oil.htm#Which%20Oil%20quality%20to%20use Silkolene Pro 4 Plus 5W40 makes a noticeable (and quite substantial, the way he writes about it) improvement even over Silkolene Comp4 10W40 (which is another very good oil), but this stuff costs £12-£15 a litre (or more as delivery is on top). Of course, it has crossed my mind that the different viscosity could been a large part of the difference.
I'm totally undecided on whether it's worth going for some "decent?" oil like Castrol / Motul at ~£25 for 4L (no point bothering with only buying a single litre), or Hein Gericke 10W40 semi-synthetic for £13 for 4L (assuming it's still available), or top money for this Silkolene Pro Plus stuff. Or even finding some very cheap and nasty semi-synthetic to really save the pennies (after all the CG apparently only needs SE grade or something). The reason this is something worth considering this time around is i'm still a student (and will be for years and years to come) and am doing particularly badly cash-wise at the moment (having to support a relationship, a CB500 and now a CG125 too, with the hope it'll save me money on using my thirsty CB500 all the time - all on a few hours a week of low pay delivery work) - so i'm weighing up the (possible?) improved MPG/whatever else i *could* get with a "better" oil, with the cost of putting that "better" oil in the bike in the first place vs cheaping out. Part of me (probably the less sensible side) even thinks i'm better off paying £1 a litre for some really naff oil and changing it more often instead. But then this part of me is usually stupid and wrong.
Edit: This offer don't look too bad at £4.80/L https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_221725_langId_-1_categoryId_165507 , especially including the freebie (unfortunately i do already have them, mind). Still open to ideas though. Especially because if Halfrauds can sell it so cheaply and even provide a freebie with it, surely somewhere else can get a similar product available at a lower price...
-- Ingah
iooi
PostPosted: 07:41 - 03 Jul 2010    Post subject: Reply with quote
Just use cheap supermarket stuff £5.00 for 5 ltr.....
Given that a Cg is a understressed engine and everyone seems to change at around 1K miles. Buying the dear stuff is a waste of time.
BanditsHigh
Worse than a woman
PostPosted: 07:46 - 03 Jul 2010    Post subject: Reply with quote
^^^ Agree with the above (well for a CG anyway) ... I buy 'ordinary' cage oil usually Castrol GTX or the Halfords stuff (GSX1400 with 53k on the clocks and still going strong).
People who buy specific motorcycle oil have far too much money as far as I'm concerned Thumbs Up
Moo.
PostPosted: 08:53 - 03 Jul 2010    Post subject: Reply with quote
I wouldnt pay massive amounts on the oil, i used asda 10w40 stuff for my cg, loves it just as much as anything else Very Happy
A2 Passed 18/6/10
virus
PostPosted: 16:58 - 03 Jul 2010    Post subject: Reply with quote
another vote for cheap nasty oil and regular (1k or so) oil changes.
I ran mine on 5w/40, 10w/40, 15w/40, 20w/50 and at one point I was running dangerously low so it got given half a litre of ATF fluid and it still didnt complain.
John
own: 81 xs1100g...
Ingah
PostPosted: 22:47 - 07 Jul 2010    Post subject: Reply with quote
OK, cheap oil it is then.
Thing is, i can't find any - does anyone know where i can get some cheap? (£4.80/L for the Halfords semi-synth) seems the best price i've seen, but isn't mineral oil cheaper still?
I don't think it's wise to use car oil - i know i could probably get away with it, but i want to at least use motorbike oil (even if it is naff stuff).
-- Ingah
Alexio
PostPosted: 23:01 - 07 Jul 2010    Post subject: Reply with quote
Morrisons value motor oil. 5L for under £5, or 1L for under £2 I think. That's what I use (it's 20w50) and as said, seeming as it's dumped for me after 1.5k it's best just sticking to the cheap stuff.
If you don't do many miles to the point where an oil change is measured by years I supposed more expensive oil would be more justified.
Ingah
PostPosted: 23:24 - 07 Jul 2010    Post subject: Reply with quote
Is that not a car oil?
-- Ingah
johnsmith222
PostPosted: 23:32 - 07 Jul 2010    Post subject: Reply with quote
there's nothing wrong with car oil especially in a cg125.
Ingah
PostPosted: 23:59 - 07 Jul 2010    Post subject: Reply with quote
OK, i'm open-minded enough to be able to reject the "car oil bad" indocrination i've had. The reason i'm concerned though, is that i have been told on various forums that car oils have friction modifiers or something (and that this is not present in bike oils) and this is bad for the wet clutches bikes use. Can i potentially expect faster clutch wear, or perhaps not because it's only a CG? Or is the whole shebang made up bull so that oil companies can rebadge oils as motorcycle-specific and charge a hefty premium for it? I don't want to save a few quid on oil now if i have to replace clutch/engine components before their time (equally, my wallet feels pain at the ~£5+ per litre that bike oils cost).
-- Ingah
johnsmith222
PostPosted: 00:12 - 08 Jul 2010    Post subject: Reply with quote
I always used asda 10w40 semi synthetic car oil in my CG with no adverse effects. Honestly, supermarket is the way to go.
Clutch slip etc really should not be an issue on the CG125 in terms of what oil you choose. You will not notice any adverse problems. Also, because the oil is so cheap you can easily afford oil changes so won't be as likely to leave it a bit longer.
Supermarket oil is fine. Oil companies tend to use big complex terminology to try and confuse people and convince people to buy their product and a lot of what you pay for is their expensive marketing schemes and the name.
I use halfords oil on my ZZR.
It's worth noting that the supermarket oil and pretty much all other oil will exceed the recommended oil requirements in the owners manual.
Alexio
PostPosted: 00:16 - 08 Jul 2010    Post subject: Reply with quote
Friction modifiers? That sounds a bit like BS to me, and for such a tiny engine like the CG engine I really don't think it's going to make much difference. Oils of different viscosity surely have varying amounts of lubrication and therefore "friction"? As in, 5w40 compared with 20w50 oil are both OK in a CG engine and those are obviously different weights.
Finally, I've never heard of a CG engine go bad specifically because of the wrong type of oil being put inside, it's a fairly low state of tune (maybe except some idiot putting 2T oil in there). My own CG has gone thousands of miles on value motor oil to no ill effect. It doesn't mention anywhere on the container it's self that it is only intended for cars.
herulach
PostPosted: 06:00 - 08 Jul 2010    Post subject: Reply with quote
some stuff does have friction modifiers and other cack thats bad for the clutch, but it's mostly stuff like magnatec you want to avoid.
YBR 125>FZS600
Ingah
PostPosted: 15:57 - 09 Jul 2010    Post subject: Reply with quote
So just to confirm, any supermarket car oil, in the range of 5W40 right the way to 20W50, is suitable? The CG sounds very unfussy Laughing
-- Ingah
johnsmith222
PostPosted: 16:01 - 09 Jul 2010    Post subject: Reply with quote
Any supermarket oil that is 10w40.
Don't get the other grades as they're not what the CG's owners manual recommends. Only get other grades if it's an emergency and cannot get hold of 10w40 oil.
kingsknight
PostPosted: 17:36 - 10 Jul 2010    Post subject: Reply with quote
yep! Ran my CG on very cheap oil! I had a 2000 CG with 30k on the clock! That bike used to drink oil! Used to drink about 0.5L every 400ish miles lol
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
LeeR
PostPosted: 18:48 - 10 Jul 2010    Post subject: Reply with quote
Wikinsons and Asda both do a budget 10w40 oil @ £2/L Thumbs Up
My claim to fame: Austin Vince nicked my pen...
The last post was made 16 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 101.35 Kb
