canon eos 350d - lens help
Blunet600
PostPosted: 15:37 - 10 Jul 2010    Post subject: canon eos 350d - lens help Reply with quote
I have just bought myself and Eos 350d and at the moment im a little lsot at how to get the best out of it but im sure in time i will learn the ropes. I only have the 18mm-55mm lens, what other lenses to people recommend for this camera? Nothing too expensive..
Honda - Power of Dreams - NSR 125R - Hornet 600
doggone
PostPosted: 16:05 - 10 Jul 2010    Post subject: Reply with quote
I've been well pleased with a sigma 18-200 on my 300D.
It can't do macro though, and only stops to F4 so limited in low light.
But for a single lens solution pretty good, sharper than kit lens.
The lens is as important as the camera don't make a false economy.
Used lenses are worth looking for - they are hard to wear out - all EF will lenses fit.
_Will_
PostPosted: 17:10 - 10 Jul 2010    Post subject: Reply with quote
Best bang for buck, a 50mm 1.8 prime.
Suffering Bike Withdrawal.
KLR600
PostPosted: 23:52 - 11 Jul 2010    Post subject: Reply with quote
+1
Small, light, cheap but most importantly gives excellent image quality for the price.
<Take Cool Photos!>
UnknownStuntm...
PostPosted: 09:31 - 12 Jul 2010    Post subject: Reply with quote
+2
It's a cracking lens, you can use the camera indoors, handheld with no flash. Providing you can get far enough away from your subject! It's a really nice sharp lens, but be careful you don't have it at it's widest setting much, the depth of field is so narrow it it difficult to get right. But if you learn how to use that lens, you'll be away in photography!
Blunet600
PostPosted: 11:09 - 12 Jul 2010    Post subject: Reply with quote
Great cheers guys, i have that in my watch list on ebay, any other lenses worth looking into? Cheers.
PostPosted: 11:29 - 12 Jul 2010    Post subject: Reply with quote
What do you want to photograph?
The 50mm f1.8 is a bargain lens and dirt cheap for what it is. The f1.4 version is even better but getting on for 4 times the price. Biggest problem with the f1.8 is that it is fairly weak and won't take much abuse.
If you want portraits then you might instead consider the 85mm f1.8.
If you are aiming to shoot bikes on track then you need something far longer. At least a 200mm lens, and preferably 300mm with the option of using a 1.4 teleconverter (and that counts out cheap lenses). Bird watching would probably want a far longer lens, but would also mean you could wouldn't be half so worried about auto focus. The Canon basic 75-300 lens isn't great but it does the job (you will get noticeable purple fringing if you shoot something white with a contrasting background.
Blunet600
PostPosted: 22:53 - 13 Jul 2010    Post subject: Reply with quote
Ill mainly be taking pictures of bikes, both still and moving. I want to take pictures like these! www.site-photography.co.uk
_Will_
PostPosted: 23:32 - 13 Jul 2010    Post subject: Reply with quote
Thats a few different types of photography on that site.
Anywho i stand by having a low light prime in yer bag, not au fait with the cannons but my nikon primes are well built and produce sharp images.
Primes will get you the best image quality for your money - it just means you have to develop skills to get the pictures by moving instead of using a zoom.
Moving bikes - if of your friends you don't need to worry too much about mega zooms, if your by the racetrack you most definitely need between 200-500mm.
PostPosted: 20:30 - 14 Jul 2010    Post subject: Reply with quote
For pics like the automotive ones there a prime (or several) will be good. Zoom can help when you can't move to get the shot, or want to arrange the shot to exclude / include items you can't move.
With affordable zoom lenses the max aperture is fairly small (and even the expensive ones still lag behind the primes), so the smallest depth of field you can get it quite large. Primes normally have far larger apertures that similar price zoom lenses.
However if shooting something moving at speed a zoom can greatly help as it is unlikely you will be able to get free choice of where to shoot from.
Digitalize
PostPosted: 20:47 - 14 Jul 2010    Post subject: Reply with quote
I've just bought a 50mm f1.8 and 55-250 IS to complement my stock 18-55 IS with my 450D.
If going for a long zoom, you need the IS, as the cheaper lenses have much slower apertures, so it gets a bit tricky. The zoom is also perfect for sports events, getting you closer to the action, through the fences etc.
To properly know what lens you want, you need to first understand all the terminology, but the 3 i have are pretty much general.
The 50mm has a small DOF, so lets you get some nice 'macro' shots, with a blurred background, the Aperture is only 5 blades, so the bokeh (Blurry circles in the background) is more of a pentagon, but i quite like that.
1998 CB600F Hornet
PostPosted: 20:59 - 14 Jul 2010    Post subject: Reply with quote
Afraid I don't really agree with that. Longer lenses land up with a shallower depth of field with a wide aperture, hence using a wide aperture means your focus needs to be far more accurate so not an easy gain. With panned shots it is fairly easy to get away with a slower shutter speed without image stabilisation, and with non panned shots it is easier to just use a tripod or monopod.
Digitalize
PostPosted: 21:15 - 14 Jul 2010    Post subject: Reply with quote
I'd much rather have the IS, for peace of mind if not anything else. Also means you dont HAVE to have a tripod, although it is a good bit of kit to have.
If it was an f2.8 lens, then i'd probably be fine without IS, but when all the way out at 250mm, its f5.6, which unless its a sun soaked day (Unlikely in England, or at rally events) the shutter speed just isn't fast enough, and the shake starts to come through. But i didn't have a tripod last time i found this problem.
1998 CB600F Hornet
PostPosted: 22:57 - 14 Jul 2010    Post subject: Reply with quote
I started out with a 75-300 which was f5.6 all the way out, and happy enough without IS on it. Have IS on my 100-400, but rarely use the lens and virtually never use the IS on it. I do have a 120-300 f2.8 and will use that with a 1.4 telephoto extender hand held (so as a ~400mm f4).
Even with a fast lens in normal daylight I will often be at f5.6 or slower using ISO 200.
Digitalize
PostPosted: 23:23 - 14 Jul 2010    Post subject: Reply with quote
Seem to be amazing at Photography and Bikes! I like you more and more... Laughing
I just feel if you can get IS, then why not, its not particularly expensive, paid £175 for my 55-250, supposed to suffer a little distortion through out, but i can afford an L series.
Any reason not to have IS on all the time?
1998 CB600F Hornet
PostPosted: 23:53 - 14 Jul 2010    Post subject: Reply with quote
Tend to find with the 100-400 that it takes a while to realise you are panning, and until then the IS tries to correct the panning movement.
I would prefer the money for the IS to instead go on a faster lens or just a better quality lens.
That said I do tend to like using slower shutter speeds. For example this photo was taken under the old Dunlop Bridge at Donington (now gone), so the bike was probably doing 150+ at that moment. From memory it was taken with a shutter speed of a 50th of a second (but doing that I had about a 95% failure rate).
Digitalize
PostPosted: 00:33 - 15 Jul 2010    Post subject: Reply with quote
Thats fair enough, but the 55-250 has IS, and its kinda hard to find a better lens for £175... The Tamron 70-300 i found the image quality to degrade far too quickly for my liking!
I'd probably rather have a faster lens too, but a similar f2.8 of that lens was £400+
Nice shot too Thumbs Up
1998 CB600F Hornet
PostPosted: 00:48 - 15 Jul 2010    Post subject: Reply with quote
That shot was taken with a Sigma 70-200 f2.8, but fairly sure at nowhere near f2.8 (was using shutter priority). I paid around £400 for that lens (gone up now) but the Canon versions were available with both an IS and non IS versions. IS added about 50% to the price.
Blunet600
PostPosted: 13:31 - 24 Jul 2010    Post subject: Reply with quote
What 1.8 prime lens will fit my camera? they are differnet and some wont fit it apparantly. My camera is a canon eos 350d.
Cheers.
_Will_
PostPosted: 15:28 - 24 Jul 2010    Post subject: Reply with quote
Cheers.
Unless canon update the mounts then any should fit?
Not sure sorry, but all nikons from 1975 have the same mount, only the lower end cameras don't have an internal focusing motor so you have to buy specific new revisions.
350d has a motor though doesn't it?
PostPosted: 15:46 - 24 Jul 2010    Post subject: Reply with quote
Canon changed their lens mount in the late 1980s. Pretty much anything since then will fit (some old after market lenses won't work as it took Sigma, etc, a while to properly reverse engineer the Canon lens communications).
The current dirt cheap Canon 50mm F1.8 will definitely fit and work.
The last post was made 16 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 127.02 Kb
