| Serendipity |
 Serendipity World Chat Champion
 Posted: 13:28 - 10 Jul 2010 Post subject: RXS100 Carb Runneth Over |
My RXS100 is once again on the road and running quite well except for a problem with the carb.
It was fine for a few weeks, and then the carb suddenly started overflowing from the breather at the base of the float bowl. The leak stops if the fuel tap is off (no kidding ).
I dismantled the carb and cleaned it all out. I made sure the float was working correctly and that the little piston it pushes was moving freely. Reassembled the carb and tested...
...still peeing petrol everywhere.
Next I took the carb off my spare bike and fitted that to the running bike. Exactly the same problem happens.
Why’s that then? Any ideas?
Cheers  ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| Serendipity |
 Posted: 16:56 - 10 Jul 2010 Post subject: |
Forget it. I just dismantled the old carb and found little motes of rusty shite in the float needle seat. I've just drained the fuel tank so I can check the filter in the petrol tap. I'm guessing it's knackered.
Doesn't explain why the replacement carb, did exactly the same trick, unless there's loads of rusty crap coming down the line and the seat got jammed immediately... ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| Dipsy2 |
 Dipsy2 Renault 5 Driver
| Serendipity |
 Posted: 22:07 - 10 Jul 2010 Post subject: |
No namby pamby dribbles here. We’re talking full on gushing!
I’ve just finished stripping and cleaning the original carb and the fuel tap. The design of the tap means that the reserve inlet is totally unfiltered. The main fuel inlet has a cool little plastic mesh filter on it. I guess all the crap got into the carb when I used the bike on reserve.
I washed all of the rusty crap out of everything and carefully assembled it all again. Filled up the tank, switched the fuel tap on and the bike started first kick. Hooray!
I ran it for a couple of minutes while talking to a neighbour before I suddenly realised it had started pissing petrol again...
... Bollox!
Going to sleep on it and have another go tomorrow. Float height is the next check as suggested by Poppy. ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| 27cows |
 27cows World Chat Champion
| russeleoin |
 russeleoin Nova Slayer
| Serendipity |
 Posted: 11:37 - 11 Jul 2010 Post subject: |
I’m fairly sure that my floats are still floaty. They’re plastic ones and have no liquid trapped in them.
I think that its chunks of rust from the tank blocking the float needle again. When I dismantled and cleaned the tap last night I noticed that what I thought was the reserve inlet was completely unfiltered. Now looking at this picture from Wemoto:
https://images.wemoto.com/full/FUEL_TAP_COMPLETE/10004593.jpg
It looks like there is a copper or brass tube on the tap, presumably for the main inlet while the filtered inlet is actually the reserve. I reckon that my tube must have vibrated off and I’m willing to bet that it’s rolling around in the tank somewhere.
More draining, cleaning and shaking in my future. ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| 27cows |
| Robby |
 Robby Dirty Old Man
 Posted: 13:29 - 12 Jul 2010 Post subject: |
Yup, inline fuel filter. Surprised you don't have one already. Go for the slightly more expensive (£2.25 instead of £1.50) paper element ones, the mesh ones are crap. Buy a handful, if there's a lot of crap in the tank you'll be surprised what you see in the filter.
The gushing is down to the needle valve seal. Seeing as you know the fuel coming in is dirty, pop the carb off again, get a new can of carb cleaner, strip out everything (including the idle jet), use the long nozzle on the brake cleaner and poke and spray it into everything (eye protection worthwhile, you'll see why). Let the carb dry out somewhere warm, reassemble to factory spec including setting the float height.
Sorted.
Don't be too rough when cleaning the rubber tip on the needle valve, and if in doubt replace. Despite being a cheap looking little thing they're quite precise and a few small scratches can make them leak. Not gush though, that's down to bits of rust. |
| Billing |
 Billing World Chat Champion
 Posted: 13:44 - 12 Jul 2010 Post subject: |
I had a very similar problem on my TZR, which has similar looking carb internals.
I cleaned the carb no end of times, checked that everything was as the factory intended and it still did it. I changed the float valve, and that seems to have cured it  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| 27cows |
| Serendipity |
| Robby |
 Robby Dirty Old Man
| Serendipity |
 Posted: 14:51 - 15 Jul 2010 Post subject: |
The tap filter on the RXS from 1995 is a little plastic tube with a plastic mesh, not unlike the mesh lime scale filter you get on a kettle. It’s very fine so should stop quite small particles while being washed clean by the sloshing of fuel in the tank. The filters should come out attached to the tap as you remove it.
The RXS tank is sort of tiny. I can get a few fingers in the filler hole, but there’ll be no reaching around inside. Also because the neck of the filler extends several centimetres into the tank it’s a bitch to bounce crap out of the tank by shaking it upside down. I can get my little finger into the petrol outlet after removing the tap and can feel the filter brush past my finger while shaking it about. I have yet to successfully trap it, but I’ll get the bastid eventually!
The tank isn’t too rusty inside, but leaving it over the winter with minimal fuel probably hasn’t done it any favours. The visible areas look pretty clear of rust, certainly better than the original tank. Although my bike is a 1986 model, this replacement is a 1994/5 tank.
I’ll have more time tonight to get this sorted. Cheers for all the help so far.  ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| Serendipity |
 Posted: 23:27 - 15 Jul 2010 Post subject: |
Right, all sorted now... ... I hope.
I used a few inches of stiff wire to hook the errant fuel tap filter out of the petrol tank. I said I’d get the sucker eventually.
The long bit of plastic is the bit that had come adrift and was rolling around the tank. It was a nice tight fit back into the tap so hopefully it won’t work loose again. This I hope will take care of 99.9% of the filtering duties. It goes back into the hole to the right of the installed reserve filter.
https://i221.photobucket.com/albums/dd227/serendipity_uk/RXS100/IMGP7033.jpg
I took the precaution of stripping and cleaning the tap. Then stripped and cleaned the carb and put it all back together.
Taking the sound advice of Messrs. 27cows and Robby I purchased an inline fuel filter (sadly a mesh, not paper one) and installed it midway in the delivery pipe. I suspect that I may have to shorten the pipe a little to stop the filter rubbing on the side panel, once reinstalled.
https://i221.photobucket.com/albums/dd227/serendipity_uk/RXS100/IMGP7034.jpg
The bike runs perfectly and, so far, no premature moistening of the crankcase. I have rather rashly left the fuel tap switched on so fingers crossed I don’t find a petroleum swimming pool in the morning.  ____________________ 2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation |
| 27cows |
The last post was made 16 years, 94 days ago. Instead of replying here, would creating a new thread be more useful? |
