2008 R1 cat removal?
gray84
PostPosted: 00:39 - 12 Jul 2010    Post subject: 2008 R1 cat removal? Reply with quote
Can anyone give me some info please?
The cat on my r1 gets damn hot and I've been told to get a y pipe to replace it. Im going to get another cat and gutt it so it looks original.
My question is. Will it make any problems or lights come on?
Thanks
gray84
PostPosted: 22:24 - 12 Jul 2010    Post subject: Reply with quote
Question Question Question Question Question Question Question Question Question Question
PostPosted: 15:02 - 13 Jul 2010    Post subject: Reply with quote
No.
It's just a box of platinum sat in the exhaust.
You'll need to check if the section you're removing as any EXUP valves or gubbins(look for the servo motor in that section), but I don't think it does.
Noxious89123
PostPosted: 22:13 - 13 Jul 2010    Post subject: Re: 2008 R1 cat removal? Reply with quote
I think they are relatively expensive, as they contain platinum... Why not just buy an aftermarket de-cat pipe. It's just a piece of stainless tubing, shouldn't look out of place.
Also, see here;
https://www.bikechatforums.com/viewtopic.php?t=153811&start=0&postdays=0&postorder=asc&highlight=
The search function is your friend. (I actually found that using google).
gray84
PostPosted: 23:33 - 13 Jul 2010    Post subject: Reply with quote
yep im finding standard cats in mint condition for £60 and a decat it £120+
plus i want it to look original.
there isnt any sensors or anything after the cat just a valve before(exup?)
it wouldnt need a pc/map would it just for a decat?
PostPosted: 10:53 - 15 Jul 2010    Post subject: Reply with quote
Yes, as the cat's pretty restrictive so it would be wise. You'll gain a fair bit of power (and noise) by dumping the cat if teamed up with a remap.
gray84
PostPosted: 14:14 - 15 Jul 2010    Post subject: Reply with quote
How would it run with out a cat and no map? I am gona get one but not yet.
Bishbash
PostPosted: 15:23 - 15 Jul 2010    Post subject: Reply with quote
I too have been looking into this, and it will run fine without a remap. But it will work better if remapped i.e. more power Wink
It should be a straight swap etc. Been looking at the Acropovic link pipes on Ebay, they tend to go for £100 - £120.
Regards the look you are on about, there is that plastic shroud covering it anyway, so you wont lose any looks at all if you swap it. Only if you bend down and look underneath from the left hand side.
gray84
PostPosted: 18:37 - 15 Jul 2010    Post subject: Reply with quote
nice one bish bash...
The last post was made 16 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 61.93 Kb
