is there a way to tell
skikman
PostPosted: 22:44 - 12 Jul 2010    Post subject: is there a way to tell Reply with quote
is there a way to tell that a bikes timing is off if its not running
fiery tupp
PostPosted: 23:01 - 12 Jul 2010    Post subject: Reply with quote
The cuckoo doesn't come out to play ! Thumbs Up
If you can't fix it with a hammer , use your head .
sniff6
PostPosted: 23:06 - 12 Jul 2010    Post subject: Re: is there a way to tell Reply with quote
Check Static Timing Marks !!!
'Great Britain' Love it https://img43.imageshack.us/img43/3967/67004290.gif or Leave it
skikman
PostPosted: 00:52 - 13 Jul 2010    Post subject: Re: is there a way to tell Reply with quote
what do i check them for there not moving
temeluchus
PostPosted: 03:19 - 13 Jul 2010    Post subject: Reply with quote
use a timing light?
If you have electronic ignition you are unlikely to have a timing problem.
skikman
PostPosted: 12:06 - 13 Jul 2010    Post subject: Reply with quote
Temeluchus wrote:
use a timing light?
could it be faulty cdi even if you have a good spark
temeluchus
PostPosted: 12:30 - 13 Jul 2010    Post subject: Reply with quote
You can roughly set up static timing if you have points.
Can only be set up with the engine running with electronic ignition as the position of the sensors dont tally with the final advance.
I would suspect an external wiring fault, faulty coil/lead/cap or a carburettor/injector fault before the ignitor. It may also be a misalignment of the ignition sensors although if they havent been touched this is unlikely. The ignitor may stop advancing if it is faulty but again this is unlikely.
Why do you think you have a timing problem?
PostPosted: 12:32 - 13 Jul 2010    Post subject: Reply with quote
It'll also help if you told us the make and model of the bike...
ssruk
PostPosted: 12:45 - 13 Jul 2010    Post subject: Reply with quote
if its the one in name thats a hyosung crusie 2 id just buy a new one or put a honda motor in it cg 125 fits well but needs a mounting plat moving
(02)hyosung crusie 2(sold) (89)cbr 600f (91) gs500ex
skikman
PostPosted: 01:31 - 14 Jul 2010    Post subject: Reply with quote
no its a wee sym fiddle 2 stroke 50 scooter.thats a lifan 2 cylinder copy of the honda cm 125
ssruk
PostPosted: 08:31 - 14 Jul 2010    Post subject: Reply with quote
looks like my hyosung lol its still a cheapo biike so id sill get a better engine in it sym are close to suzukis i think if its the same as the hyosung it may not have a timing mark (well its a grove) may need put a white mark on it to see it with storb gun
The last post was made 15 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.83 - MySQL Queries: 13 - Page Size: 77.09 Kb
