Brake bleeding problem??
paddlesat16
PostPosted: 22:29 - 12 Jul 2010    Post subject: Brake bleeding problem?? Reply with quote
Hi guys
Bike=cb250nb Superdream 1982
it had no problems before I rebuilt the braking system, except thirty year old braking system.
First off I have rebuilt the brake master cylinder with new internals, new reservoir cup and seal, replaced the brake line with a stainless steel goodridge jobby, new bleed nipple, I have left the caliper alone for the moment.
The problem is the system won't bleed now, I have replenished the fluid etc, following all the brake bleeding techniques from off of here and u-tube videos. I cannot get a hard(harder) lever what so ever. I have back filled etc but to know avail.
I do notice though I seem to get micro bubbles when I bleed, this to me indicates I have a leak somewhere.
what do yah reckon? One of the seals?
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
PostPosted: 22:42 - 12 Jul 2010    Post subject: Reply with quote
I would strip and rebuild the caliper first.
PostPosted: 23:09 - 12 Jul 2010    Post subject: Reply with quote
I have a very similar (if not the same) brake system on my bike.
Replace your banjo washers if not new.
Think you may of answered your own question regarding the seals.
I replaced mine and the dust seal. Also the sealing band on the lower bolt. Oh..and the rubber boots on the bracket.
*I found that reverse filling then doing the 'pull lever almost to bar then close the bleed nipple' way worked.
*Long version
Fill reservoir-spanner on nipple- tube on nipple - tube submerged in a pot of fluid.
Rag just in case tube pops off.
Pump lever to build pressure and then simultaneously start pulling the lever as you loosen the bleed screw. Before you reach the bar close the bleed screw. Watch the air get pushed out. Repeat a few more times then tap the banjos and lines. Keep going until no bubbles get pushed out.
Takes up to 10mins from a completely empty system (reverse filled via a syringe)
If you do strip down the caliper etc keep everything really clean.
Let us know how you get on.
Pat
fiery tupp
PostPosted: 23:11 - 12 Jul 2010    Post subject: Reply with quote
It could be air behind the piston ? push it all the way in & clamp it for a while & bleed with it in first then release & continue , I have done this before & ok so maybe worth a try eh Question .....R
If you can't fix it with a hammer , use your head .
paddlesat16
PostPosted: 14:09 - 13 Jul 2010    Post subject: Reply with quote
Hi guys
Thanks for all the reply guys,
First off the banjo's and washers are new they came with the goodridge hose.
Keith: I have left the caliper till funds reappear, superdream should be renamed money pit...
Pat: I will try your techniques as described, over the weekend when more time allows.
I was advised last night by a mate to clamp the lever and leave it overnight, this will show up any leaks at the joints.
I will post more when more progress is made.
Cheers for your combined help guys Very Happy
PostPosted: 14:22 - 13 Jul 2010    Post subject: Reply with quote
Main place for leaks are the seals. You have replaced those in the m/c and also the sealing crush washers, hence why I suspect the one remaining set of seals (ie, the calipers seals) and the ones to check.
In the short term pump the piston out, take the seals out and clean up behind the seals. Check the seals carefully. Many people reuse seals.
paddlesat16
PostPosted: 22:13 - 18 Jul 2010    Post subject: Reply with quote
Update time:
So I had no joy with the master cylinder at all, more of the same(micro bubbles in the fluid) but I couldn't find the leak. I suspect the new O-Ring between the fluid cup and master cylinder.
I decided to replace the master cylinder in the end with an item from wemoto, hence even more poor now. Amazingly quick service, I ordered in the afternoon and it arived next morning.
Good news
Fitting new brake master cylinder 10mins
filling cylinder with new fluid and bleeding probably another 5 mins
and instant hard lever. Very Happy
calyx
PostPosted: 14:08 - 20 Jul 2010    Post subject: Reply with quote
So the problem was this?
Boris - London
Dazbo666
PostPosted: 14:23 - 20 Jul 2010    Post subject: Reply with quote
Had a similar issue after I'd fitted the new braided hoses on the Bandit. In my case, I managed to use the old pads to push the pistons further apart, with the result that the air behind the pistons was pushed back up into the hose and bubbled back up to the reservoir.
Then, I just topped up the reservoir, bled the brakes as normal, and job's done! Thumbs Up HTH
Word of the day : DILLIGAF
The last post was made 16 years, 23 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.02 - MySQL Queries: 13 - Page Size: 64.46 Kb
