Preservative spray stuff?
loply
PostPosted: 22:10 - 13 Jul 2010    Post subject: Preservative spray stuff? Reply with quote
Hi folks,
I've read on various occassions about a spray that you can spray onto bolts, metal bits, etc, and it cakes up into a hard kind of waxy substance.
The idea is that it looks pants, but the nut or bolt underneath remains sealed and protected. I guess it chips off easily when required.
Anybody know what it's called and if it's any good?
Thinking about lathering some on a bike which I have to leave sitting outside unfortunately.
Cheers,
Rich
Yamaha SZR660 Caution to the wind, the throttle pinned!
neatbik
PostPosted: 22:16 - 13 Jul 2010    Post subject: Reply with quote
acf50
https://www.acf-50.co.uk/
really good stuff, i use it and it really helps keep corrosion at bay.
You can also use FS365, it needs applying more often though.
https://www.scottoiler.com/FS365-Protector.asp
radical
PostPosted: 22:19 - 13 Jul 2010    Post subject: Reply with quote
The long lasting product is called Waxoil, Tetraseal make a good one, try Ebay item 250 646 820 319 @ 5.35 per can.
Noxious89123
PostPosted: 22:29 - 13 Jul 2010    Post subject: Reply with quote
Tbh, FS365 is pants. ACF50, now that is the dogs danglies!
DrDonnyBrago
PostPosted: 22:43 - 13 Jul 2010    Post subject: Reply with quote
ACF-50 costs a lot but it's v good.
FS365 is a cheaper not quite as good alternative.
WD Forte
PostPosted: 14:18 - 14 Jul 2010    Post subject: Reply with quote
It sounds like you're describing the aforementioned waxoyl
Ditto the ACF50 comments, good stuff !!
My old Cx had its swing arm flooded with old engie oil
after I repaired/welded it and
the frame tubes were treated with ACF50 internally
cos they all rot from the inside out.
Anythings better than nothing though
steel rusts, ally oxidises so any exposed areas
will benefit from old engine oil, WD40, copperslip, grease,
vaseline etc to protect it from the elements
if you dont have anything more expensive or better to hand
bikers smell of wee
leenit
PostPosted: 14:28 - 14 Jul 2010    Post subject: Reply with quote
beatnck2 wrote:
acf50
acf50 Thumbs Up
+1
Maruchino
PostPosted: 20:11 - 14 Jul 2010    Post subject: Reply with quote
Another one here for ACF50.
Proper detail clean once before winter, apply ACF50 liberally (whole spray can will do it), don't wash bike for whole winter, spring arrives have a clean up and you'll be amazed at the results!
Noxious89123
PostPosted: 23:49 - 14 Jul 2010    Post subject: Reply with quote
A whole can?! Shocked
mattgirv
PostPosted: 01:44 - 15 Jul 2010    Post subject: Reply with quote
I don't tend to use a whole can in one go, but I do find it tends to wear off exposed parts after a while. I generally have a can last me a year or so.
As for the price, I find it fairly reasonable considering how long it lasts.
Bikes: 1998 Honda VFR800Fi, 26,500 miles Laughing
1989 Honda CB-1, 38,000 miles
bEN_
PostPosted: 16:58 - 15 Jul 2010    Post subject: Reply with quote
I recently purchased 'muc off' protective spray, can't comment on how good it is as the bike is only a few months old Laughing
2010 Ducati 848 Dark
Lamp Post Enthusiast
Maruchino
PostPosted: 20:12 - 15 Jul 2010    Post subject: Reply with quote
Yup if you're taking the fairings off and coating the engine/exhaust in every spot possible a full can is easily done.
Given that I just let the shit stick to it over the winter and wash off once in Spring it works out well.
garth
PostPosted: 22:58 - 15 Jul 2010    Post subject: Reply with quote
TBH can't go wrong with a brush and a tin of grease. Works for me.
Bike will look fucking skank though....
loply
PostPosted: 13:35 - 16 Jul 2010    Post subject: Reply with quote
I thought about that, but does it not eventually freeze/drip/run off? Especially if it gets rained on?
Anyway. I ordered some ACF50 folks, thanks for the advice!
The last post was made 16 years, 70 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 82.26 Kb
