| warren1290 |
 warren1290 L Plate Warrior
| Casper |
 Casper World Chat Champion
| warren1290 |
| Casper |
| Kickstart |
 Kickstart The Oracle
 Posted: 00:30 - 15 Jul 2010 Post subject: |
Have you drained the system totally? If so it can be a pig to get fluid through again. However if you have just removed the m/c it shouldn't be too bad. If so then connect it back up, fill the m/c with fluid and pull the lever VERY lightly and release it. Keep doing this. Just pulling the lever enough to dislodge air bubbles back into the reservoir.
| warren1290 |
| Kickstart |
| warren1290 |
| Casper |
| warren1290 |
| Kickstart |
| warren1290 |
| bacon |
 bacon World Chat Champion
 Posted: 14:59 - 15 Jul 2010 Post subject: |
you might also find as you have drained your mc, you need to bleed the mc first before you have any chance of getting pressure in the system
*fill res with fluid
*open the banjo bolt next to the mc,
*pull lever back slowly, tighten the banjo bolt before you finish the pull
*slowly let go of the lever, and repeat until fluid starts flowing from the banjo bolt (have a rag held over it so you dont get any on your bike
Now the mc is bled, continue the usual way with the rest of the system, (undo bleed nipple, pump lever, tighten nipple before lever is fully pulled in, rinse repeat), making sure you keep the mc topped up, if air gets in you effectively will be back to square 1
Give it a go, good luck mate, i learnt the hard way with brakes, im pretty handy at them now as a result haha |
The last post was made 16 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
