Rear Sprocket
Mini_Stalk
PostPosted: 00:39 - 15 Jul 2010    Post subject: Rear Sprocket Reply with quote
Hello i am thinking of getting a 3 tooth less sprocket for my yamaha sr 125 but as i understand it, it will lower my accelaration so would it be worth getting a different frount sprocket.
Thanks
Dave
SR 125 Rat
Paxovasa
PostPosted: 08:13 - 15 Jul 2010    Post subject: Reply with quote
What do you want?
A smaller front or larger rear sprocket will give you better acceleration. If you do both then there will be no difference.
Fitting a smaller front sprocket will give you better acceleration and it might improve the top speed as you may be able to redline it in top gear.
fiery tupp
PostPosted: 11:28 - 15 Jul 2010    Post subject: Reply with quote
If you need a new rear sprocket its best to get the standard size & then you can try either one tooth more or less at the front as these are only cheap & experiment , But with the yam sr 125( Ive just sold one) I wouldn't bother theres not much if anything to gain .
If you can't fix it with a hammer , use your head .
Mini_Stalk
PostPosted: 15:01 - 15 Jul 2010    Post subject: Reply with quote
i see, i just want a bit of a better top end cus it pisses me off stitting at 65 everyware.
SR 125 Rat
bacon
PostPosted: 15:13 - 15 Jul 2010    Post subject: Reply with quote
Paxovasa wrote:
What do you want?
that doesnt make sense
small front = better acceleration
larger rear = better acceleration
If you do both, you will have even better acceleration, they will not cancel eachother out
Mini_Stalk
PostPosted: 15:26 - 15 Jul 2010    Post subject: Reply with quote
bacon wrote:
Paxovasa wrote:
What do you want?
So if i get a smaller frount and rear it will give me better acceleration and top end.
SR 125 Rat
RussG
PostPosted: 15:38 - 15 Jul 2010    Post subject: Reply with quote
Yeah smaller front or larger rear.
If the front has to complete more whole revolutions than the rear you should (in theory) accelerate faster Smile
Geek, father, biker
PostPosted: 15:40 - 15 Jul 2010    Post subject: Reply with quote
No. It is the ratio of the front to the rear that is important. Say you have 15:45 gearing. If you went to 14:42 (ie change you suggest) then the ratio is EXACTLY the same so the gearing is the same. No change in acceleration or top speed
fiery tupp
PostPosted: 16:25 - 15 Jul 2010    Post subject: Reply with quote
So if you put a bigger sprocket on the front less acceleration setting off & at lower speeds & about half a mph faster top speed when you eventually get there in about mid august Wink sept if its wind is against you & if theres any hills on your route send us a xmas card Laughing
bacon
PostPosted: 16:36 - 15 Jul 2010    Post subject: Reply with quote
no its done in ratio's
14/42
15/45
16/48
for example are all the same, ratio of 3 (rear teeth / front teeth)
Higher the ratio, faster acceleration, lower top speed
Lower the ratio, slower acceleration, higher top speed
There are obviously other contributing factors, like the power of your bike and aerodynamics etc, that mean you cant get a cg125 say doing 120 despite the gearing allowing it
Mike
benlooker
PostPosted: 19:49 - 15 Jul 2010    Post subject: Reply with quote
Hi, i kind of understand the theory behind how changing sprockets can alter acceleration/top end.
I am ready for a new chain and sprocket set for my Honda XL 125 and have been looking at getting a different set ie front -1 and rear +2 to increase the top end.
My bike struggles to hit 65 and is revving very high at 60. Would altering make a noticeable difference in top speed?
I would like to be able to hit 70 and sit at 65 comfortably, or higher if possible but not expecting for anything unrealistic.
PostPosted: 20:02 - 15 Jul 2010    Post subject: Reply with quote
Smaller front or a larger rear will LOWER the gearing. Lower gearing = more revs for the same speed. If you are running out of revs then you need higher gearing so a larger front or smaller rear sprocket.
However an XL125 is unlikely to go much quicker anyway. Not much power and a flying crucifix riding position to maximise wind resistance.
Mini_Stalk
PostPosted: 22:08 - 16 Jul 2010    Post subject: Reply with quote
Thank you all for you help Smile Smile
SR 125 Rat
The last post was made 16 years, 91 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.81 - MySQL Queries: 15 - Page Size: 78.78 Kb
