| McJamweasel |
 McJamweasel BCF Junkie
 Posted: 20:42 - 06 Jul 2010 Post subject: Spec me a PC |
Wotcha.
Right, my PC is now about 6 years old and I think it's time for an upgrade. However, I also lost touch with the technology sometime shortly after my last upgrade so I'm after some advice.
I've got about £300 to spend, I won't need hard drives, a case or optical, maybe not a PSU unless they've changed from whatever it was for socket 939 boards.
I do a bit of gaming but not massive amounts so the graphics don't need to be awesome but onboard isn't going to cut the mustard either.
For now I'm probably going to stick with XP, but I'm sure I'll end up with Windows 7 at some point. Is it possible to pirate that or am I going to have to part with actual money for a Microsoft product?
Cheers. ____________________ BCF: Be yourself, just don't be an arse. |
| Frost |
 Frost World Chat Champion
| divuk83 |
 divuk83 World Chat Champion
| Scotsman37 |
 Scotsman37 World Chat Champion
| Frost |
| Scotsman37 |
 Posted: 09:49 - 14 Jul 2010 Post subject: |
| DaFrostyOne wrote: | I seriously doubt any person could tell the differences between instruction sets and architecture on an AMD / Intel processor just by using it. Your problems were most likely due to the motherboard where you do indeed get what you pay for.
Currently i consider the AMD's best value for money and exactly as compatible with everything.
The differences are suttle but more so when it comes to laptops, as the AMD's architecture is based upon an older design while Intel redeveloped their's to maximise the potential of the dual/quads, etc, according to from what I've read up on the subject.
There is so many cheap variations on design especially for the AMD motherboards because the processors are sold more cheaply and that's why you have to buy a motherboard from a reputable company i.e. Asus for good BIOS/driver support, but Intel has been a firm favourite for software houses because it's a solid & dependale and most of them design their software/hardware around it and that's why Intel based systems costs more.
If you ever to AMD's website you need to got their user forum website to get help regarding compatibilty problems either with hardware/software, while Intel regularly maintains their support with updated driver releases which isn't needed much because it's so well designed!
I have had an intel based system and AMD desktop system and I get more errors with AMDs rather than the later because of either software problems or possibility AMD processors are usually pushed closer to their maximum operating temperature while Intel prevent overclocking to maintain stability, and this is more acute with laptops (I own intel based one and AMD version). That's why Intel based system are more stable in that area because they have a greater safety margin of normal operating temperature and, therefore, less likey to slow down to compensate for the increased operating temperature because that's why you see so many crazy looking different types of cooling systems for AMD processors to keep them cool for overclocking as they need it. p.s. you void your manufacturer's warranty if you overclock your processor.
So Intel is a more stable platform, in my opinion and concurred by my friends, while the later potentially requires more cooling to sustain it's true AMD designed performance when run at maximum for sustained periods i.e. gaming, as it has a smaller margin of space for increased temperature before having to slow down to keep it from over heating which can potentially cause the program to crash or slow the program to an unacceptable speed. This happens far more with my AMD based systems rather than intel version.
I will NEVER waste my money on an AMD based system ever again, as they are just not worth the money in the long run if you want to maximise it's use with stability!
As I said before you get what you pay for! |
| Frost |
 Posted: 11:01 - 14 Jul 2010 Post subject: |
Software developers don't design software to work on a single processor type, it defeats the point of the hardware / software abstraction layer. Also it is almost impossible that any of the errors you have seen have been caused by processor miscalculations or architecture design. Graphics card chipset has a great deal more to do with system stability as it is usually an overclocked or overheating graphics card that gives visual errors that bring down a system.
Currently Intel are using smaller transistor technology which does result in a cooler running more power efficient system, but thats why they are damn expensive. The smaller technology is more likely to power leak and cross talk so it definatly wouldn't be considered a stability advantage.
When you say that intel doesn't sell overclocked stuff this is true, no manufacturer does. The processors are all made to the same design in the same factory and are then tested. The ones that pass are sold as the top end ones, those that fail are down clocked till they start working and sold at that speed. If a whole core is fucked in a quad core, they disable it and sell it as a triple core etc. So people selling an 'overclocked' system are doing so without AMD's autheriseation. Saying that they are less stable as a result is like saying Hayabusa's are shit bikes cause you bought a 600bhp turbo one and it melted a piston  |
| Scotsman37 |
 Posted: 11:35 - 14 Jul 2010 Post subject: |
[quote="Saying that they are less stable as a result is like saying Hayabusa's are shit bikes cause you bought a 600bhp turbo one and it melted a piston [/quote]
Talking about Suzuki in that I had bought one not long off the production line and it was performing poorly from the start and I complained a few times, and eventually the mechanic discovered debris in carbs no doubt left in there when it got assembled at the plant. So, it comes down to quality control by saying if you don't maintain quality throughout you'll get a bad reputation for producing crap!
I got rid of that suzuki asap and bought a Honda instead, now that one purrs like a kitten and never gave me any trouble!
So, what I am saying that I have tried desktop/laptop based systems and found them to be poorer cousins to the Intel for stability. That's what I have experienced.
In regards to graphic card, yes they can cause system to either hang or slow down due to the demands of the game or just the driver needs updating to overcome incompatiblity problems either with the hardware or software errors within the game itself.
My gripe is with AMD based systems not the graphics card as that is a seperate issue.
Software houses can only build their software around a certain number of complete system configurations which they think best represents the users because there is such a wide variety of setups out there that incompatibility will no doubt arise, which means at some point work around will have to be made otherwise if it's just a tiny number of users effected with a certain hardware configuration why bother as it's not cost effective in the end as the majority are fine! |
| Casper |
 Casper World Chat Champion
 Posted: 13:11 - 14 Jul 2010 Post subject: |
You will get a nice dual core bundle for under 140 quid. Just made my seld one but i spent closer to 200 as i needed an extra HDD.
https://www.novatech.co.uk/novatech/bundles.html
Yes you will need Windows but we all know where to get that for free. |
| Scotsman37 |
 Posted: 15:29 - 14 Jul 2010 Post subject: |
| Frost |
| Scotsman37 |
| Frost |
 Posted: 19:13 - 15 Jul 2010 Post subject: |
Exactly, an AMD system  |
The last post was made 16 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
