| muffy |
 muffy Borekit Bruiser
| Kickstart |
 Kickstart The Oracle
 Posted: 10:47 - 16 Jul 2010 Post subject: |
Think that Motad claimed that they did not need rejetting (they claimed that with the GPZ500 we had), but need and could do with are different.
However that said the behavior your bike is showing sounds far worse than I would expect from the carbs needing minor changes for the pipe.
Floats probably use a metal tag to act on the needle valves and you probably bend these tag a tiny amount to set the float height. Also worth checking the needle valves are in good condition while you are there. ____________________ Traxpics, track day and racing photographs - Bimota Forum - Bike performance / thrust graphs for choosing gearing |
| muffy |
| Kickstart |
 Posted: 11:16 - 16 Jul 2010 Post subject: |
Not certain if the idle mixture adjustment on the GS carbs is an air screw or a mixture screw, so undoing it could make the mixture richer or leaner!
Needle valves tend to wear and needle little wear to leak.
I would be inclined to check the carb rubbers are not cracked and that the needle jets are OK, and that the diaphragms are not perished.
If the carbs still appear OK then it is probably easiest to lob it on a dyno and have a look at the mixture trace.
| muffy |
| Kickstart |
| WetSparks |
 WetSparks Renault 5 Driver
| muffy |
| Kickstart |
| el_oso |
 el_oso World Chat Champion
The last post was made 16 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
