CB250N Sprocket wobble.
Moo.
PostPosted: 14:59 - 17 Jul 2010    Post subject: CB250N Sprocket wobble. Reply with quote
Hey guys.. basically, the sprocket wobbles for some reason, i've checked a parts list, its all there spart from a dust cover. It sits inside the wheel on rubber wheel dampers, slots in.. then theres a small washer.. and a bit of a gap before a circlip oes on.. Anyone shed any light? Shagged rubbers or something?
A2 Passed 18/6/10
muffy
PostPosted: 15:08 - 17 Jul 2010    Post subject: Reply with quote
if the sprocket wobbles it could be worn cush drive rubbers which are easy to replace just take off rear wheel lift out srocket and changed the black rubbers
mr.kris
PostPosted: 20:30 - 17 Jul 2010    Post subject: Reply with quote
lol change chush drive dont be a fool cut up an old iner tube and pad it out with that job done!
TS50X---CM125---MZ150---Z250---RS125---ZXR250---BANDIT600---TRX850---TL1000S---CBF600---ZX6R---BANDIT1200S---CG125---VFR800---CBR1000F---CG125---CG125---CB900F---CB900F---CG125---TUONO1000R---KLR600---GSX1300R HAYABUSA---VFR400NC30---BANDIT1200---CG125
HAYABUSA now in use!
andys675
PostPosted: 21:44 - 17 Jul 2010    Post subject: Reply with quote
there's a metal insert in the middle of the original sprocket that you have to tap out and knock into the pattern (non-honda) replacement, sounds like someone left it out, they're available here
https://www.patternbikeparts.com/productinfo.asp?ProductID=1283
or here
https://www.bitzforbikes.co.uk/Sprocket_Insert.-ref-12253-846-90.html
The last post was made 16 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 43.79 Kb
