RXS 100 oil pump
vmax12
PostPosted: 19:27 - 17 Jul 2010    Post subject: RXS 100 oil pump Reply with quote
just got this wkd bike, needed a bit of work electics, piston n rings etc...back together now, just took the pump cover off and 2stroke p***ed out. the pump looks new for being a 91.....any ideas why this would happen? im yet to get a manual off of flebay.... cheers guys
27cows
PostPosted: 19:50 - 17 Jul 2010    Post subject: Reply with quote
Either the two screws holding the pump to the case are loose, or the main (thick) oil pipe is split. Can't think of anything else it could be.
vmax12
PostPosted: 10:20 - 18 Jul 2010    Post subject: Reply with quote
thanks guys, i just found the bleed screw snaped off and the hole filled with some sort of glue, and oil was coming out of there. i was able to fit a very short screw that sat flush and tightend up, hopefully it will hold and stop the leak......wont be able to bleed system tho but as its been doing this all along i dont think it would need it.....what do yous think? thanks in advance
vmax12
PostPosted: 13:36 - 18 Jul 2010    Post subject: Reply with quote
hi, there is whats left of the original bleed screw still in the hole, there was enough thread to screw another short screw in.....ive just had it ticking over for a while and noticed an oily residue running down the down pipe from the cylinder head end.....its not blowing tho. i had a scooter that did the same but that was over jetted.....120 main jet in at the mo
vmax12
PostPosted: 19:07 - 18 Jul 2010    Post subject: Reply with quote
finally got the the rest of the thread out with a needle and a stanley knife blade, it was actually quite loose luckly.....i do need to know if the pump is set correctly tho... see pic, its as it is with the throttle closed and engine off....... Thumbs Up thanks
27cows
PostPosted: 19:59 - 18 Jul 2010    Post subject: Reply with quote
Needs a bit of adjustment - the punch mark should line up with the pin with the throttle closed. Probably wouldn't make that much difference, though.
vmax12
PostPosted: 22:05 - 18 Jul 2010    Post subject: Reply with quote
thanks for all your help guys Thumbs Up
The last post was made 16 years, 105 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.39 - MySQL Queries: 13 - Page Size: 63.06 Kb
