| chuffzilla |
 chuffzilla L Plate Warrior
| stonesie |
 stonesie World Chat Champion
 Posted: 19:51 - 15 Jul 2010 Post subject: |
What type of battery is it? Maintenance free or normal?
If it has a cap on each cell then check the water level (Electrolyte/acid, Top Up with De-ionised water from your local motorfactor if required)
The next test is a 'Drop test' .... Noooo, Don't drop it on the floor
Leave the multi meter/volt gauge attached to the battery and try the starter while looking at the voltage display, a good battery should not drop below 10v, if it does then it has a damaged cell and that warranty you got with it will come in handy
If it is charging at 13.8v then the generator is working, set your MutleyMeter to Amps (highest range first) and disconnect the battery +ve.
With the ignition OFF connect the multimeter +ve to the battery and -ve to the bikes +ve connector this will tell you how much drain there is on the battery and you can go through the fusebox to track down which circuit is causing it. |
| fiery tupp |
 fiery tupp Trackday Trickster
 Posted: 20:13 - 15 Jul 2010 Post subject: |
Yeh , got same bike k6 though ive had no electrical probs I dont like the fact that you can't turn lights off . I very rarely do less than 30 up to 50 miles on any day that I ride it wich is most days , so maybe if you're doing very low mileage or stopping & starting often could have a bit to do with it I dont know ? I think the advice given by stonesie sounds good . Also if it was me I might be tempted to put it on a trickle charger once or twice a week . But you still need to get to the bottom of the prob so good luck with it ...R ____________________ If you can't fix it with a hammer , use your head . |
| skatefreak |
| chuffzilla |
| chuffzilla |
| chuffzilla |
 Posted: 12:29 - 17 Jul 2010 Post subject: |
Ok drop test done
with ignition off i get about 15V from the batt
ignition on and lights off i get about the same
lights on I get about 13
but when I try to start the voltage drops right down to 0.3 - 1.5
I think it is safe to say that the battery is probably toast even though it is less than a couple of months old.
I have tried draining it down and charging it up at but even when (apparently) fully charged it can't keep the headlight on full beam for more than 10 mins)
Ok so lesson learned, lots of short trips turn my battery into expensive paperweights, but can it be rescued? and does anyone think this is the root of the problem or could it be something else?
my charger is a numax 12V 2A bike charger https://www.brooksbarn.co.uk/NUMAX-BATTERY-CHARGER_ARSIZ.aspx |
| forx |
 forx L Plate Warrior
 Posted: 16:25 - 17 Jul 2010 Post subject: |
probably worth getting an optimate 3 or 4,bout £35 on flebay to keep the bat in good condition.
only other thing that springs to mind,n i dont KNOW the bike model at all,is perhaps the valves need adjusting ala a service is due?.
have no experince of small bikes but my trident 900 had much the same thing and on the trumpet forums they diagnosed it needed shimming as they are famous for valves tightening up and causing same symptons as you have.
hope its some help.
| Fortuna |
 Fortuna World Chat Champion
| fiery tupp |
 Posted: 19:42 - 17 Jul 2010 Post subject: |
I dont think that the low milage you are doing is the main problem though after reading what you are doing , it should be enough to keep a good battery charged , though a good run now & again will do it good , You should check for any bad connections clean & spray with wd40, the first being the main earth lead at the back of motor , then rectifier & coil ect ... ... R ____________________ If you can't fix it with a hammer , use your head . |
The last post was made 16 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
