Iphone white screen, new LCD?
Misc
PostPosted: 23:38 - 17 Jul 2010    Post subject: Iphone white screen, new LCD? Reply with quote
Evening,
Can't find these symptoms anywhere. I have a white inverted screen on my 3G, no blacks just faint white. You can use the phone as normal but is quite hard to see around. The start screen is white with a silver apple instead of a black screen & everything looks low quality. The settings menu looks fairly normal but other then that..
I've reset, restored, updated & all of that but nothing. The screen was fine before i change the digitizer & in doing so i cracked the digitizer screen. Although cannot see that having any effect. I've pressed all connections down firmly, check & rechecked but it's still the same.
New LCD?
Cheers.
T1z3R
PostPosted: 23:55 - 17 Jul 2010    Post subject: Reply with quote
if you had to remove or even disturb the LCD connector then strip it and reseat it.
duck my sick!
Misc
PostPosted: 00:02 - 18 Jul 2010    Post subject: Reply with quote
What do you mean by strip it? And this is connector '1'?
Cheers.
T1z3R
PostPosted: 13:29 - 18 Jul 2010    Post subject: Reply with quote
strip the phone and reseat the connector for the display.
duck my sick!
Misc
PostPosted: 14:01 - 18 Jul 2010    Post subject: Reply with quote
If you mean remove everything inside the phone i.e logic board, i've done that a few times now, so much so that i think i now know where every screw goes from memory. Shocked
Or did you mean something else? Each time i removed the board, i put it all back but got the same white screen.
T1z3R
PostPosted: 00:51 - 19 Jul 2010    Post subject: Reply with quote
no, that is what i meant.
if youve already checked the connector then something else is at fault.
could be mainboard socket, display connector or screen itself.
duck my sick!
Misc
PostPosted: 00:54 - 19 Jul 2010    Post subject: Reply with quote
Thanks mate. I think i'll order a new LCD which will 'hopefully' fix the problem.
Are the cheap ebay LCD's fine to use? Noticed some come with a warranty but seem a little cheap as there's ones for triple the price.
T1z3R
PostPosted: 08:06 - 19 Jul 2010    Post subject: Reply with quote
yeah source and cheapness wouldnt bother be.
as long as its the right model it should be fine.
duck my sick!
Misc
PostPosted: 20:26 - 19 Jul 2010    Post subject: Reply with quote
Will order one tomorrow.
Thanks for the help.
The last post was made 16 years, 58 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 58.35 Kb
