more carb problems/fuelling problems
el_oso
PostPosted: 18:08 - 19 Jul 2010    Post subject: more carb problems/fuelling problems Reply with quote
still having problems with the divvy. managed to free up the throttle sliders that were sticking by giving them a thorough clean and polish. have completely taken the carbs apart to clean and reset everything but there is still a problem. if pull the choke out, the bike dies. the bike also seems to idle when it feels like it. when i first start it up, it usually idles fine at around 1k. after a 2minute ride around the block it will sometimes just cut out at a junction. it starts again fine on the button again, just doesn't like idling.
also if i increase the idle speed using the adjustment screw the revs return much slower to a normal idle speed after revving, even with less than a quarter turn on the adjustment screw. with more than a quarter turn the revs will stick at around 3k until you turn it off and restart.
any ideas anyone. i am just about to go find the balancing stuff and balance the carbs and see if that fixes the problem. i doubt it will. but i will give it a try
Duke 390
Car: Jeep Wrangler 4.0L
yen_powell
PostPosted: 18:15 - 19 Jul 2010    Post subject: Reply with quote
Are the carb rubbers between the carb and engine perished or leaking?
XT1200Z and a DR350 in bits
el_oso
PostPosted: 18:30 - 19 Jul 2010    Post subject: Reply with quote
nope, checked for leaks and there doesn't appear to be any
Duke 390
muffy
PostPosted: 14:47 - 20 Jul 2010    Post subject: Reply with quote
if its slow to settle to idle after reving its running lean
el_oso
PostPosted: 19:49 - 23 Jul 2010    Post subject: Reply with quote
balanced the carbs and still no improvement. this really has got me stumped.
anyone living in the hornchurch/romford areas fancy giving me a hand with this. can pay you in crates of beer/cash if you are able to lend a hand and get this irritating problem sorted.
Duke 390
The last post was made 15 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 42.98 Kb
