| c_dug |
 c_dug Super Spammer
| Itchy |
 Itchy Super Spammer
 Posted: 21:22 - 19 Jul 2010 Post subject: |
Probably so you can keep your hands on the bars and thus rev the engines up as you need to on IL4s in a car your foot does this. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Redoko |
 Redoko World Chat Champion
 Posted: 21:54 - 19 Jul 2010 Post subject: |
I think C_dug was hoping for a really in dept conversation/discussion.
Itchy ruined it with being logical.  ____________________ "Let's face it, this is not the worst thing you've caught me doing."
Sudika Sportsman SK50QT > Gilera DNA50 > Honda CBR125 RW7 > Kawasaki Zephyr750 > Suzuki GSXR600 > Honda Hornet CB600F '51 |
| Fisty |
 Fisty Super Spammer
| steppen22 |
 steppen22 World Chat Champion
| Charlie |
 Charlie World Chat Champion
| panrider_uk |
 panrider_uk World Chat Champion
| radical |
 radical Spanner Monkey
| Gazz |
 Gazz World Chat Champion
 Posted: 22:30 - 19 Jul 2010 Post subject: |
Could be....
Incase you left it in gear and started it like a car ignition, and the bike jumps forward.
P.S. - I did this in my car today.
I fail.  |
| radical |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 02:08 - 20 Jul 2010 Post subject: |
I presume you mean push button start, rather than ignition.
The ignition is the circuit that works the spark-plugs that light the fire in the engine.
In days of yore, engines were started by variouse means, depending on what they were fitted to.
The earliest motorbikes were created by attaching a simple engine to a standard push-bike.
This was how Harley-Davidson and many others started out, and many contemprary 'Cycling' magazines carried articles about how to 'motorise' a bicycle, while I think it was De-Deon / Minerva actually sold 'plans' of thier single cylinder engine, for the enthusiast to make thier own, on a 'single licence' basis, a bit like buying a copy of MS Windows for 'home use'!
These 'Auto-Cycles, of course still had pedals, and the starting operation was to pedal up to speed, then tug a lever to engage 'Drive', usually a belt or sometimes a friction wheel, engaged by moving the engine so that the friction wheel touched the tyre or the belt gripped the pulley.
At which point the bicycles momentum made the engine turn, and after a few cycles, with the rider fiddling the advance and carburation controls.... if they were lucky..... it would 'catch' and start tugging them along!
In about 1904... a chap called Alfred Scott, had been messing with engines based on Benz designs, and had come up with two stroke engine, with water-cooling.
Looking at what he could do with it, he first put it in his boat.
Then he looked at his bicycle.
He thought about this for a while, and decided that strapping his engine to the bicycle was not the best way to begin, and set about designing one of the first purpose built motorcycles.
https://upload.wikimedia.org/wikipedia/commons/7/72/Scott_Squirrel_486_cc_1923.jpg
(1923 Scott 'Squirrel'; the 'Edwardian Elcie'. Looks like something out of a Jules Verne Novel, but the features it had were pretty advanced right up until the 1985 Yamaha RD350YPVS. In the mid 1970's when in a slightly more contemprary frame, with slightly more conventional styling, the Scott engine, built from the original tooling as the 'squirrel' was marketed as the Silk!)
It was remarkably advanced, and featured amongst numerouse innovations, a kick-start. He had no pedals.
This innovation, like the cranking handle on early cars, or the earlier pedal starts, started the engine on mechanical enertia, provided by human effort, and remained the most prevalent means of starting a motorcycle for generations to come.
So, historically, the motorcycle evolved with a switch for the ignition circuit, to allow the engine to be switched off once running, and an kick-starter for spining the engine over to get it started.
That switch, eventually evolved into a key switch, but the kick-start remained.
Then came the electric start, and the kick-starter replaced by an electric motor.
(Only it wasn't! Early Electric starters were so unreliable, that they left the kick-start mechanisms in place, so that when the e-start packed up, you could still get to work!)
But as standard ignition switches didn't have a contact to work a starter motor, simplest solution was to stick a buttom some-where to work it. On the handle-bar seemed convenient.
It has stuck ever since.
Oh, the 'key-start' on cars is a reletively modern thing too. On older cars, the cost and reliability of solenoids which makes a key-start feasible by having a low amp feed to power a solenoid 'switchg' to turn on the high ampage feed for the starter, meant that they too had push-buttons or pull-toggles. These had a spring and a big plate on the back to bridge the high amp starter wire. Reliability of solenoids didn't really become good enough or cheap enough for the average car until the late 1950's early 1960's to use key switches for the starter. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| deleted111 |
 deleted111 World Chat Champion
| 2wheelsteve |
 2wheelsteve Spanner Monkey
 Posted: 21:13 - 21 Jul 2010 Post subject: |
Safety  ____________________ Ride Safe |
| Chalky. |
 Chalky. World Chat Champion
| mistergixer |
 mistergixer World Chat Champion
| WetSparks |
 WetSparks Renault 5 Driver
 Posted: 09:16 - 22 Jul 2010 Post subject: |
Bring back the kick start, all this wussy bloody electric starter nonsense  |
The last post was made 16 years, 85 days ago. Instead of replying here, would creating a new thread be more useful? |
