CG epic fail :'(
stonesie
PostPosted: 20:35 - 19 Jul 2010    Post subject: Reply with quote
What colour was the plug?
Were you on reserve fuel?
It could be some crap deep within the carb that's making it run lean as hell.
stonesie
PostPosted: 20:50 - 19 Jul 2010    Post subject: Reply with quote
Really dark, sounds like rich so the crap could be around the float/needle valve not letting it close, that ties in better with closing the idle mix screw to improve it.
My last encounter with the recovery services involved him having a quick look then loading it up and taking me home, must have been a better bloke if he was carb stripping at the side of the road Smile
radical
PostPosted: 21:06 - 19 Jul 2010    Post subject: Reply with quote
does sound fuel related with some crud getting into the carb, try fitting an inline filter on the fuel line for future use and clean the carb out, also check your airbox and airbox drain for signs of moisture and clean or replace your air filter if necessary.
radical
PostPosted: 21:43 - 19 Jul 2010    Post subject: Reply with quote
They are ultra reliable but need the same care and attention as any bike does, most CG 125s die an early death because people refuse to change or even top up the oil and expect them to run forever on air and nothing else. Sounds like you have allowed the fuel to run low and the carb has picked up some crud or water from the bottom of the tank which would stop any bike from running right.
cb1rocket
PostPosted: 22:01 - 19 Jul 2010    Post subject: Reply with quote
naff petrol?
radical
PostPosted: 22:10 - 19 Jul 2010    Post subject: Reply with quote
cb1rocket wrote:
naff petrol?
very good point, picking up the drags from a near empty storage tank, its happened before Thumbs Up
Nemo
PostPosted: 22:25 - 19 Jul 2010    Post subject: Reply with quote
radical wrote:
cb1rocket wrote:
naff petrol?
I used to work in Esso, they don't let it get that low, they turn the pumps off before that happens Thumbs Up
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
cb1rocket
PostPosted: 09:39 - 20 Jul 2010    Post subject: Reply with quote
training schools would more than willing to help, where i got my hire bike from - 20 quid an hour but that was 7 years ago
cb1rocket
PostPosted: 10:03 - 20 Jul 2010    Post subject: Reply with quote
thats what i did, had the instructor with me, did a little last minute training, but didn't follow me on the test. Just the examiner
Odie
PostPosted: 11:16 - 20 Jul 2010    Post subject: Reply with quote
Condesers from old minis fit, get them from car care shops, clean points and fit condenser, should sort
rob_scott92
PostPosted: 15:15 - 20 Jul 2010    Post subject: Reply with quote
Awwww dude no! Just got back from down south and read this thread.
This seriously isn't good, you've killed a CG Shocked
You can still buy my GS if you want, its got about 10 mins left on ebay though Laughing
Other than that, if you use a training schools bike then i think you will have to have had some training with them, although some may be willing to take you out an hour before your test, but that means extra dosh Rolling Eyes .
Wheres your test at anyways, st.helens?
Dont suppose all your lights went out when it happened did they? I had a similar thing on the Gs, where i rode off and there was a big bang from the exhaust. All the electrics had gone due to a loose connector block. I assume the guy at the garage checked the wiring?
First bike: 1982 Suzuki Gs 125 'The beast MK1' Wink > 1988 Honda Cb 350's' FOR SPORT! (Good ol' oil burner!) > 2001 Suzuki Sv 650 's' Made it out of the 80's! > 1997 Honda Cbr 600f :p
UnknownStuntm...
PostPosted: 15:36 - 20 Jul 2010    Post subject: Reply with quote
Just a shot in the dark but have you looked really carefully around the exhaust header to check for a leak? If you spray some soapy water over the area when the engine is idling, you might see bubbles... An air leak might cause those issues..
rob_scott92
PostPosted: 15:38 - 20 Jul 2010    Post subject: Reply with quote
Best of luck dude, let us know how it all pans out Wink
UnknownStuntm...
PostPosted: 15:50 - 20 Jul 2010    Post subject: Reply with quote
Ah, well then, um, no. You can check for a spark by taking the plug out and holding it against the engine, with some pliers or mole grips or something.
The last post was made 15 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 134.19 Kb
